RADIO LED
Old 02 Apr 2014, 10:32 pm
Default RADIO LED
Hello everyone, please help I have a 2005gt turbo convertibile my radio LED goes off and on. when first starting my car no music or LED shortly after music and no LED short time later both music and LED working
Old 03 Apr 2014, 07:56 am
Handy_Cruiser's Avatar
Default Re: RADIO LED
The stock radio lights are on a separate circuit from the radio itself. This allows them to dim with the dash lights. Also, I found that after installation of my Mopar subwoofer, there is a one second or so delay before the radio comes on after I start the car. I don't know which radio head you have, but some delay may be normal.
A cheap and easy thing to try first might be to remove the plugs from the back of the radio head, check them for corrosion and then reinstall them. You might just have a loose connection. All you need to do this is a Phillips screwdriver and some kind of non-scratching pry tool to pop out the window switch. After removal of the window switch, you will see one Phillips screw to remove. After the screw is removed, pull off the four AC knobs. Then the bezel will just pop off if you pull gently. There are four Phillips crews holding in the radio. Remove those and the radio will slide out.
Old 04 Apr 2014, 04:32 pm
rcktpwrd's Avatar
Post Re: RADIO LED
check out this thread, specifically the pics in post #9
Horn and Radio Screen Intermittent?
Joel
www.rcktpwrd.com
Old 04 Apr 2014, 05:34 pm
Are you talking about the stock radio?
I have never seen a stock radio with LED's
Installed New Radio, Interior Lights wont wont, Radio Doesnt receive "Constant" Power Mc5Cent Interior Accessories Forum 0 08 May 2013 06:12 pm
P8?? on the radio Popdart General PT Cruiser Discussions 8 28 Mar 2011 07:48 pm
what's behind the pt's radio? geronimo Interior Accessories Forum 7 19 Jul 2009 03:23 pm
XM Radio Stephen R. Sound and Security Forum 1 20 Mar 2002 01:03 am
