Use optional fact sub wiring for aftermarket install
Like Tree5Likes
Old 03 Apr 2014, 11:36 pm
Default Use optional fact sub wiring for aftermarket install
Can the wiring for the optional factory sub be used for adding an aftermarket amp/sub? Im assuming the wires are there even if the opt sub isnt. Its a 2006 base. Thanks. Also are the wires there i can use for line level input to new amp?
Old 04 Apr 2014, 01:57 am
Default Re: Use optional fact sub wiring for aftermarket install
Mopar subs suck
No you have to run the wiring for the mopar sub
Don't waste your money and buy a good amp/ speaker box combo
Mopar subs suck, oh wait I already said that
Old 04 Apr 2014, 02:43 am
Ray_Dockrey's Avatar
My Mopar sub works just fine. I like it especially for what I paid for it. But Busa is right. The wiring is not there.
rckstein likes this.
Old 04 Apr 2014, 06:40 am
Handy_Cruiser's Avatar
First, the Mopar subwoofer is awesome. If you like clean clear and well-balanced music, adding the Mopar sub to the original stereo system is a great option.
And yes, you can use much of the wiring for an aftermarket sub. However, that wiring does not come standard in the PT. It all comes in the box with the Mopar sub and must be installed.
Of course, even if you have the Mopar sub wiring harness, it provids only a "line-level" output. A better method would be to run an RCA-level output to the aftermarket sub's amp. If you are using the stock stereo head, you will need an adapter like this one. Just like the Mopar sub wiring harness, this will leave the stock speaker wiring intact. But it adds RCA outputs for an aftermarket sub with its own amp.
One more consideration is the power for the subwoofer amp. The Mopar sub amp only pulls 80 watt. While that's far more than is needed for clear enjoyable music, most aftermarket subs use much more power. So you will need some kind of an amp power supply kit to do the job right.
And on a 2006 PT, the power supply kit becomes even more important since tapping into existing power can cause all kinds of unwanted effects due to the CAN Bus system.
Old 04 Apr 2014, 08:40 am
So...I need mobar sub harness, PAC RCA output and a Power supply kit? Seems like a lot of trouble.
Old 04 Apr 2014, 02:00 pm
It all depends on what you are going to do. And if you don't already have a Mopar subwoofer, I wounldn't buy one just to get the harness.
Instead, you will have to tell us more about the rest of your sound system in order to get more specific recommendations. What head unit are you using? Will your sub have a dedicated amp? And does that amp have RCA imputs or "old school" line-level inputs? The more we know, the more we might be able to help.
Old 04 Apr 2014, 07:42 pm
it provides only a "line-level" output. A better method would be to run an RCA-level output
You can order the wiring with RCA-level ouput when you purchase the sub on Ebay. Cass Daniels who sells the subs will send you any type you request. I bought a sub w/ line-level outputs off a member from PTCrew years ago. Had Cass send me new RCA wiring this year for about $ 25.
Original join date: SEP 2003
Steve/ Wayne NJ
2005 GT Vert / Black / 5 speed
2004 Dream Cruiser / 5 speed Traded for 12 Veloster
2003 GT / Blue / Auto /sold
2001 Touring/ Silver / 5 speed /sold on E Bay
Old 04 Apr 2014, 10:57 pm
That's very cool, especially if someone wanted to mod the sub with an aftermarket speaker and amp the way NitroPT and some others have. Cass seems like a very cool guy. He actually called me on the phone to ask if I was happy with my sub.
Old 05 Apr 2014, 08:41 pm
Ive got an MTX thunder amp with rca and line level inputs. Amp will power one 10" sub. The radio and all speakers are stock. No oem amp or sub. Thinking of using line level inputs from left rear speaker and mount amp under driver seat. Im guessing i can get to left rear speaker wires in pillar and run thos to new amp under seat.
Old 23 Apr 2014, 11:21 pm
MUS1C4U's Avatar
Yes, he is a very cool guy. I purchased a mopar sub from him just this week. Went down and picked it up in person(apparently I am only the second person to have done so). He gave me a bit of the lowdown on how he came to acquiring so many, some specs, good information, etc. while he was finishing soldering the wiring harness for me(I wanted mine with preamp RCA leads to plug into the aftermarket head unit I am putting in).
I'm still not sure if I am going to keep the OEM driver in the box, but the amp should power a lot of different options that have a higher efficiency that the OEM. We shall see when I install it early next week(waiting for the head unit to do it all at once).
2003 Limited
In its natural habitat.
2005 Dream Cruiser
2003 PT Cruiser Limited
2010 Town and Country Limited
1992 Fifth Avenue
It appears we have a bit of a Chrysler fetish in this house...
Aftermarket Fan Wiring Help gmrviper General Turbo Discussions 9 18 Feb 2014 04:14 pm
Aftermarket radio install superjew78 Sound and Security Forum 7 02 Aug 2012 09:17 pm
aftermarket radio install berk3066 Sound and Security Forum 5 28 Dec 2010 05:07 pm
Aftermarket Radio Install DaJ4ck3L Sound and Security Forum 8 18 Aug 2010 04:59 pm
Wiring Mopar Sub to aftermarket stereo Bevynn Sound and Security Forum 6 21 Mar 2010 03:36 pm
