would these work
Old 05 Apr 2014, 12:33 pm
Default would these work
for front and rear,im looking for direct drop in , no adapters etc... thanks,also if i have rear size off what is it?? thankyou
Kicker 40CS674 Car Audio Stereo 6 75" 2 Way CS Series Speakers Set Pair 6 3 4" | eBay
2005 PT CRUISER GT
Semper Fidelis!!!
Old 05 Apr 2014, 12:39 pm
Default Re: would these work
Rockford Fosgate P1675 120 Watts 6 75" 3 Way Coaxial Car Audio Speakers 6 3 4" 780687340339 | eBay
or these, they have the adapters for the rear, if i have sizing correct, front drop in rear, included bracket....and there 3-way!
2005 PT CRUISER GT
Semper Fidelis!!!
Old 06 Apr 2014, 11:25 am
anyone??
2005 PT CRUISER GT
Semper Fidelis!!!
Old 06 Apr 2014, 03:57 pm
Ray_Dockrey's Avatar
There isn't a direct drop in for the front. You have to use an adapter. Not sure about the very backs but those adapters should work.
Old 06 Apr 2014, 04:14 pm
randyincctx's Avatar
Question Re: would these work
I'm actually gonna use a version of your statement from the earlier thread: "Why wouldnt you just get 6x8 speakers,they dont make them that size?"(You said it first;Not me)....You'll get a little more low-end Hz from the 6x8,and you wont even need an adapter,because they're an exact drop-in for the OEM speakers.(even a 5x7 would be a better choice for rear than 6.75?)
You still need OEM plug adapters,unless you plan on doing a cut-n-splice using the connectors from the new speakers(wiring normally included).
BTW....R/F does have 6x8s,and they are also 3-way:
http://www.ebay.com/itm/Rockford-Fos...item19d5ff2699
Aka:~KILLER~
Old 06 Apr 2014, 04:34 pm
rckstein's Avatar
BTW....R/F does have 6x8s,and the are 3-way also:
Rockford Fosgate P1683 3 Way 6" x 8" Car Speaker Brand New P 1683 6x8 780687329044 | eBay
Chrysler must have changed the door speaker sizes on different model years of the PT, I recently changed all (4) door speakers on mine and all (4) were 6-1/2". These are what I got off ebay, direct replacement for the stock and wiring plugged right in, no modifications necessary.
Dodge Chrysler Jeep Kicker Speaker Upgrade Mopar 77KICK10 Speaker 2 Factory | eBay
Old 06 Apr 2014, 04:45 pm
Cool Re: would these work
Yes.....You have a Gen-2 PT(2009),the OP has a Gen-1 PT...(clearly says 2005 in the sig.)
I purchased the Rockford Fosgate R168X2 Prime 6"x8" 2-Way speakers for my rear speakers(located in the D-pillars on Gen-1 PTs):
http://www.ebay.com/itm/ROCKFORD-FOS...item4d182510b4
Those IMO are a better choice than a 3-way,because for staging & imaging,you normally want your highs in the front of the vehicle & as close to ear/head level as possible,and obvoiusly a 2-way will produce less highs than a 3-way(w/extra tweeter).....I actually considered a 6x8 woofer,or 6x8 component set,and maybe place the satellites in the B-pillar(1st choice) or C-pillar(2nd choice)....Maybe,later I might switch to one of those though.
Aka:~KILLER~
Old 06 Apr 2014, 04:50 pm
rckstein's Avatar
OK, thanks, I knew he had a Gen-1, I just didn't know they changed speaker sizes between Gen-1 and -2. Mine is an '06 Touring Edition.
Old 06 Apr 2014, 05:03 pm
You can't compare those to regular speakers because those are direct replacements for Chrysler cars. They have the adapters built into them. Normal speakers require adapters.
I bought Rockford Fosgate 6 3/4 speakers and had to have the adapters. The back door speakers screwed in the plastic but the fronts have to have adapters. Again, what you bought are special. No other speaker comes that way.
Old 06 Apr 2014, 05:29 pm
Radio Stereo Speaker Wire Harness Adapter Plug | eBay
so i need these, and what adapters for front speakers, and im figuring 4 total, of these, and 2 adapters, as the 2-stage rf's are drop in
2005 PT CRUISER GT
Semper Fidelis!!!
will it work ? jsrodri83 Tech & Performance Forum 3 03 Dec 2013 02:04 pm
what do you do for work? jbaer1 Gulf PT Forum 0 28 Mar 2010 10:31 am
Will this work? stirfry Sound and Security Forum 1 08 Apr 2004 03:47 pm
If you do ANY of your own work... PTRON General PT Cruiser Discussions 0 21 Feb 2004 10:45 am
