Does anyone have the speaker wire color codes for a 2004 PT GT? I'm looking for the coding and the door and rear pillar speakers only.
Thanks.....Chupacabra |
REAR RIGHT + DB/WT X REAR RIGHT - DB/BLK X REAR LEFT + BR/YL X REAR LEFT - BR/LB X DOOR LEFT + DG X DOOR LEFT - BR/DB X DOOR RIGHT + VT X DOOR RIGHT - DB/RD
hey looking for wiring diagrams for the pt crusier's security system and starting system. can you help?
If it\'s to loud your to old. |
Chupacabra, dollymama, welcome to the forum!
![]() 2002 Inferno Red PT Limited Photos and more at: http://www.randgraphics.org/PT_Cruiser/demos/index.htm Mercedes Wiki |
Hi Guys,
Thanks for the info BLH1 and thanks for the welcome IRPT. One last question and then I'm ready to start working on the system. Does anybody (especially from experience) know where the best place(s) to splice into the door and rear pillars speakers is (are)? Thanks and I'll let the forum know how things turned out. Adios....Chupacabra |
For the doors easiest is before the bundles reaches the pass-through for each door.
For the rears it depends on what you're doing. If you're adding an amp that will be housed under the front seats the best place is right under trim plastic trim next to the door sills. That's where the bundles run towards the back. There's a fair amount of room under there for wires/connectors. If you're mounting the amp in the back the easiest place is to pull the rear pillar speaks and tie in there. |
Chupacabra
The pinout I have found is as follows: 1st the 10 pin connector to Multiplexor (or CD Changer or Sirius if you only have one BTW: Sirius does not display INFO in these config. at least it didnt for me...)[xx(] # 1 Audio R # 6 Audio L # 2 Audio Gnd # 7 Batt Gnd # 3 Shield # 8 (Spare) # 4 J1850 # 9 PWD # 5 ACC/IGN #10 Batt + Next the 22 pin connector to Speakers Etc. #11 Batt #22 Batt #12 ACC #23 Radio ON Out #13 PWD #24 J1850 #14 (Spare) #25 EVA Mute #15 (Spare) #26 (Spare) #16 (Spare) #27 (Spare) #17 RF+ #28 LR+ #18 RF- #29 LR- #19 LF- #30 RR- #20 LF+ #31 RR+ #21 GND #32 GND Be very careful with the color code I have found many differences. Peace JC |
| 2003 Error codes | Reed | Tech & Performance Forum | 4 | 15 Aug 2007 08:12 am |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Check engine light, ever hear of these codes? | MINIHEMI46 | Turbo Performance | 6 | 10 Jul 2006 07:41 pm |
| Check Problem Codes Yourself! | turbomangt | General PT Cruiser Discussions | 13 | 23 Feb 2006 06:27 am |
| Computer wiring color codes | Ian-PT-GT | Turbo Performance | 3 | 06 May 2003 01:48 pm |
