Radio wont hold it's code
Like Tree3Likes
Old 17 Sep 2014, 02:07 pm
ProperTricky's Avatar
Default Radio wont hold it's code
Every time i start the car i have to enter the code to get some tunes so is the radio knackered or could this be rectified ?
Nuclear Sector sorting out the electrons, neutrons and croutons
Old 17 Sep 2014, 02:21 pm
Default Re: Radio wont hold it's code
What year car, is it a factory radio, and do you have a multimeter?
Old 17 Sep 2014, 02:27 pm
It's a 2002 and an original radio ...
Yes I have a meter.
Old 17 Sep 2014, 03:04 pm
Your a lot better off putting your question on the EUROPE PT FORUM under Regional Forums as none of the United States PT Cruisers came from the factory needing a code.
rob342 likes this.
Old 17 Sep 2014, 03:13 pm
on the radio there should be a pink wire with a light blue stripe. make sure that has 12v+ with the key on. then make sure it has power with the key off.
if it does not have power with the car off, you will need to clip the wire off and attach it to somewhere else. easiest would be to connect it to one of the top row fuses in the interior fuse box by using one of these fuse taps from a local parts store.
on the other hand, if you DO have 12v to that wire with the car off, the problem is likely inside the radio. if that's the case, it may be a good time for you to consider an upgrade.
i've attached a wiring diagram for the radio.
Old 17 Sep 2014, 03:15 pm
are you implying darwin didn't live in central Florida?
Old 17 Sep 2014, 05:13 pm
rob342 likes this.
Old 17 Sep 2014, 05:15 pm
If he had the avalable info we have today he would toss his conclusions and start over. But now we are stuck with it as fact. Kinda like the internet huh.
Old 18 Sep 2014, 10:42 am
Rob you're a star thank you ..
Investigated today and the wires have been meddled with so i might just put proper connectors on and put it back how it was ..
Oh and, there's only power at the wire when the ignition is on
Old 18 Sep 2014, 02:10 pm
Exclamation Re: Radio wont hold it's code
Thanks for the pic and Wow that's some pretty shady wiring. Hope you get it back to normal. -rob
wont hold fluid welshdude2 Tech & Performance Forum 10 15 Apr 2014 05:38 pm
Installed New Radio, Interior Lights wont wont, Radio Doesnt receive "Constant" Power Mc5Cent Interior Accessories Forum 0 08 May 2013 06:12 pm
P0340 error code and wont start. jdwalk04 Tech & Performance Forum 5 28 Apr 2012 12:05 pm
P0340 error code and wont start. jdwalk04 Tech & Performance Forum 0 27 Apr 2012 11:23 am
Aftermarket radio wont turn on and off with ignition Samson Sound and Security Forum 8 23 Jan 2010 12:09 am
