12v ignition on in overhead console?
Old 03 Oct 2014, 04:16 am
Default 12v ignition on in overhead console?
Hi everyone,
New to this forum. Just purchased a 2001 Limited for my daughter and had a question. Looking to install a backup camera/rear view mirror. I need to connect the mirror to a ignition on power source and obviously a ground. I don't want to run a lead from the mirror down to fuse panel so I was hoping that there would be a hot lead in the overhead console. She has the factory power roof, compass, outside temperature and map lights. There has to be something up there, correct? I'm sure I can find the ground. Also, how would I remove the console to get there?
Thanks!
Steve
Old 03 Oct 2014, 09:41 am
sanatanadharma's Avatar
Default Re: 12v ignition on in overhead console?
Look for the pink wire (20gauge) at overhead console connector pin #4. It is a battery hot lead protected by fuse #13 (10 amp) in the dash fuse block.
To remove the overhead console (easier than it sounds):
Grasp the front of the overhead console and pull downward to disconnect the front retaining clips from their slots.
Slide the overhead console forward to disengage the rear tabs from the headliner.
Disconnect the overhead console wire connector and unsnap compass module from inner roof panel by pushing the module all the way forward to disengage the front retaining clip. Once the front clip is disconnected, push the module all the way rearward to disengage the rear retaining clip.
Remove console from vehicle.
From a post when I installed an overhead console, for reference. I cut the headliner hole in the picture.
Posting in stealth will not be permitted in most threads please read the forum guidelines.
looking for overhead console jrbsr05pt Classifieds: Want To Buy 11 20 Feb 2013 01:16 am
Three different OEM 1st gen overhead console sanatanadharma Interior Accessories Forum 8 19 Nov 2012 09:19 pm
Overhead Console Henton Tech & Performance Forum 10 22 Feb 2011 02:19 pm
Overhead Console bkarr Interior Accessories Forum 4 31 Mar 2007 02:19 pm
Overhead console gonzomania Interior Accessories Forum 7 16 Jul 2005 12:10 pm
