CENTRAL LOCKING NOT WORKING 2.2CRD
Old 31 Mar 2015, 01:11 pm
Default CENTRAL LOCKING NOT WORKING 2.2CRD
Hi i have a 2006 2.2 CRD. the central locking will not work in any way.
the fob will set the alarm as normal. Have checked the fuse etc.
I also cannot locate the RKE module. it isnt in the top of the dash.
Anyone got any ideas?
Old 31 Mar 2015, 02:02 pm
LionPT's Avatar
Default Re: CENTRAL LOCKING NOT WORKING 2.2CRD
Pull off 1 of the rear door panels to see if you have a power actuator installed...it should be bolted just left of center towards bottom...it is about 12" long.
I can't seem to find a pic of one at the moment.
Old 31 Mar 2015, 02:48 pm
sanatanadharma's Avatar
The second generation cruiser does not have an RKE Module.
The functions of the RKE have been integrated into the instrument cluster.
Posting in stealth will not be permitted in most threads please read the forum guidelines.
Old 31 Mar 2015, 03:27 pm
LionPT's Avatar
I didn't know that...because I've never had that issue
Old 31 Mar 2015, 04:27 pm
Is your gas gauge, temperature indicator and MPH & RPM gauge working?
Old 01 Apr 2015, 01:12 pm
hi all many thanks for your replys.
what does the actuator do? and what am i checking for?
All other gauges work fine, the alarm works too. !!!
Old 01 Apr 2015, 01:54 pm
LionPT's Avatar
There is an actuator in each door & the hatch, when you press the button on the alarm the drivers door unlocks...when you press it twice all doors unlock.
Old 01 Apr 2015, 02:16 pm
ok willl all four be faulty or just a rear one?
Old 01 Apr 2015, 02:27 pm
LionPT's Avatar
In my 2006, only the front doors worked (2 of 5). I tested the wiring & couldn't find anything wrong, I removed the actuator & tried to jump it off the battery & it didn't move...so I took a chance & bought a rear door actuator off eBay for $18.
I jumped it 1st & it worked, hook it up & the door locked & unlocked fine...so I bought the other side & that worked also. It took my awhile to find one for the hatch though...and now that works also.
One thing I did notice during all this, opening the rear doors & hatch would not set off alarm...once I replaced the 1st door actuator the alarm would go off whenever I opened the hatch. The lock still didn't work, but it did give it power or complete the circuit.
I'm not say all 5 of your are bad, just that I had 3 bad ones. It still could be something else.
2006 Power Lock Question
Old 01 Apr 2015, 02:41 pm
could one faulty one stop all of them working?
Central locking not working Freddedw General PT Cruiser Discussions 10 11 Apr 2012 08:11 am
Central Locking fastdel Tech & Performance Forum 1 16 Sep 2009 05:14 pm
central locking key AlexJB Sound and Security Forum 1 18 Jun 2008 08:47 pm
central locking AlexJB General PT Cruiser Discussions 10 05 Jun 2008 11:01 pm
central locking not working alicelaura Sound and Security Forum 4 12 Jul 2007 02:28 pm
