cant get past step one....
  • 1 Post By scroller
Old 22 Jul 2015, 09:14 pm
Default cant get past step one....
Is there some trick to getting the screws out (inside the vents) so I can get the center panel off to replace the stereo????? I have been trying all the phillips head screwdrivers that I have and these things wont budge...the driver spins off and I feel like Im going to break thru the back. Its kind of like they used locktite or something to that effect. So any suggestions?????
Thanks
Old 22 Jul 2015, 09:29 pm
Default Re: cant get past step one....
i used my little makita impact driver. overkill for sure, but sure is easy.
it shouldn't be that hard with a decent screwdriver. try putting a vise grip (or channel locks)on the screwdriver handle so you can push harder and turn easier.
after re-reading that...
**by screws in the vents i think you need to remove the window switch and turn the screw behind there instead. there's no screws in the vents
Welcome to the forum
Try to state the year and model at least with your questions when you start threads. It will hepl others to help you!
Old 22 Jul 2015, 09:31 pm
older pt:
2006 and up:
Old 22 Jul 2015, 09:33 pm
Rob I think he talking about the center facia (1st gen)which only has screws behind the window control switch panel ? The vents and facia panel then pops out. I have noidea what screws he is after?
Old 22 Jul 2015, 09:36 pm
Your quick tonight Rob. I am pecking away on the cell phone. Lol
Try NOT to use screw drivers to pry plastic parts.
Old 22 Jul 2015, 09:38 pm
Oops sorry about that, This is a 2007 Limited Edition I believe. Yes, the two screws I am talking about are in Robs video....those are the first step to pulling this off, but only if I can get them off lol.
Thank You
like these, except they wont budge
Old 22 Jul 2015, 10:40 pm
Hey Rob, channel lock idea worked on the passenger side Thank You for that. Tomorrow I will see if someone has a impact driver that will fit the drivers side. Thanks again
rob342 likes this.
