CD Changer
Old 24 Jul 2015, 03:13 pm
Default CD Changer
My Cruiser is equipped with the 6 disk CD changer. When I press the Mode Switch and then the number I disk button, the disk loads but then is ejected with a disk error message. What am I doing wrong? I'm a CD Changer virgin and have no idea what I'm doing. The owner's manual is no help with this problem.
Old 24 Jul 2015, 03:33 pm
LionPT's Avatar
Default Re: CD Changer
Try pushing 2-6 and see if they work or not.
Hit the 'Load' button and insert a CD into 2-6 to see if it's just the '1' slot that has a problem or all of them.
EDIT: You have a 2003, different radio than my 2006...don't know if it works the same way or not.
Old 24 Jul 2015, 05:41 pm
Does the disc get sucked in and then spit out right away? If so, I have had a similar thing happen and it is when there is something inside that shouldn't be there. Usually it is a disc that has popped out of the little internal stacking tray and is impeding the mechanism. You could remove the radio and pot the top cover off and pear inside. You can do some further dismantling and if you do it gently you should be able to get it back together and hopefully it will be working again.
Old 24 Jul 2015, 09:11 pm
Did you try a different disk?
6 disc changer sleepy General Turbo Discussions 5 08 Nov 2012 01:00 pm
In need of OEM six disc Cd changer! jingks Classifieds: Want To Buy 5 03 Mar 2009 11:15 pm
cd changer zebra3 Classifieds: Want To Buy 1 06 Sep 2008 08:54 pm
6 CD Changer TurboNNN Sound and Security Forum 0 11 Apr 2003 01:00 pm
CD Changer rhale Sound and Security Forum 1 13 Jan 2003 11:35 am
