No power to aftermarket or stock radio
  • 1 Post By LionPT
Old 25 Aug 2015, 01:09 am
Default No power to aftermarket or stock radio
I was installing my double din head unit using the bracket from amazon. I connected the wire harness from crutchfirld and it worked fine. I then disconnected and began to shave down the space for the double djn head unit to fit. But now when connected, the radio will not turn on. I repeat, it worked before... And not anymore. I didn't change any of the wiring. Fuse #15 is not blown... I think...
Everything else works. Ac, lights power doors. Just not the aftermarket radio through the radio harness or the stock radio through the stock connections.
Do I need a multi meter? On and by the way, for those who have done it, how did you particularly shave or cut enough space to fit a double din head unit? Mine is not clean St all. My battery died today. I got it tested and said it was low. I just got s new one. I tested both radios again and neither worked. Still no idea what to do to listen to music!
--2006 pt cruiser non turbo owner. Completely stock... For now.
Old 25 Aug 2015, 05:50 am
LionPT's Avatar
Default Re: No power to aftermarket or stock radio
Look at fuse #20
Gkon likes this.
Old 25 Aug 2015, 03:05 pm
Tldr. That worked.
Went to lunch, opened fuse box and saw it was blown. I'm ecstatic because I originally thought I ruined the security system or fried the head unit. Connected everything again and replaced the fuse... Everything worked perfectly! I now have an extra USB charging port, aux in (I broke mine on stock head unit) hd radio, bluetooth,... Just thinking I should have splurged an extra $400 for navigation... I'll just upgrade my phone instead and use those dash attachments instead.
What caused it to blow a fuse? An exposed wire from the wire harness? Does each end need to go into a crimp if it is unused?
Old 25 Aug 2015, 03:50 pm
LionPT's Avatar
Originally Posted by funkyfred View Post
Tldr. That worked.
Don't know what caused it to blow...and yes, either crimp or tape them up.
Old 25 Aug 2015, 04:34 pm
Gkon's Avatar
Tldr. That worked.
If you were installing the radio without having disconnected the battery, you likely shorted live wire out and blew the fuse.
I'm only guessing, but seems likely.
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
Old 26 Aug 2015, 02:21 pm
That makes sense as well. I was moving the wires around while kry was in the ignition and sometimes not. One of the power wires is live and uncapped (no crimp attached, open wire. Just never had the rubber stripped so I'm sure it made contact to a metal surface.
Now to make another thread asking how to upgrade my speakers.
Again, thanks everybody! Still need to clean the trim job so it looks cleaner inside though nobody will ever see it.
Old 26 Aug 2015, 03:33 pm
Gkon's Avatar
Do a search in the Sound ANd Security portion of the forum. There's plenty to read there.
aftermarket radio in 06 06OregonCruiser Sound and Security Forum 13 29 Apr 2015 10:06 pm
Aftermarket amp to stock radio skyline842 Sound and Security Forum 1 02 Mar 2015 08:16 am
Replace Stock radio with Stock Chrysler Nav 01Pittypat Sound and Security Forum 0 24 Sep 2010 03:58 pm
Aftermarket radio help gmariconda Sound and Security Forum 1 05 Jan 2010 04:01 pm
Stock Sirius Radio and Aftermarket Headunit? blueberrygt Sound and Security Forum 1 17 Apr 2005 08:41 am
