Stereo can't see led, red lines
Like Tree5Likes
Old 20 Mar 2016, 10:45 pm
Default Stereo can't see led, red lines
My friends pt just got a new issue. The stereo works, but the lcd does not work. It "powers up" but I only see some red lines lit up.
I read about bad ground in the steering wheel. Also something with the key slot. But it seems to be getting power, but lcd is busted.
Any ideas?
Thanks
Old 21 Mar 2016, 06:43 am
LionPT's Avatar
Default Re: Stereo can't see led, red lines
I'd say the screen is bad...a bad ground wouldn't cause that problem.
Old 21 Mar 2016, 06:49 am
Handy_Cruiser's Avatar
Here the pinouts. You could have a bad ground (11 & 22), bad battery positive , bad acc. positive (2) or bad panel light connection.
And if you think it's the ground, just hook a wire to the stereo chassis and ground it to the negative terminal on the battery to see what it does.
Old 21 Mar 2016, 07:48 am
rckstein's Avatar
Handy_Cruiser likes this.
Last edited by rckstein; 06 May 2016 at 02:26 pm. Reason: Removed because some other forum member wants to control the entire forum.
Old 21 Mar 2016, 09:21 am
Originally Posted by rckstein View Post
What year PT is it from? What model stereo? Look below one of the knob for some small letters.
+1
Good point. My advice was based on the OP's friend having a 1st Gen PT with an oval face stereo unit. If it's a 2nd Gen PT, the pinouts will be different. We need more information.
Old 21 Mar 2016, 10:25 am
rckstein's Avatar
Old 21 Mar 2016, 11:02 am
I don't know about the Gen1 stereos, but my Gen2 RAQ has a replaceable faceplate. On mine, a section of the back light led's went out. They are not replaceable, but I was able to find on Ebay a replacement faceplate for $15. Remove a few screws and detach a ribbon cable onto the main board, and back in business.
On the 1st Gen stereos, the LED will sometime go a little crazy or not work at all if all three power wires (bat., acc. & panel light.) are not connected or if the ground is bad. And course, the LED screen or other electronics could just be faulty too.
Old 21 Mar 2016, 11:49 am
I have a dumb question.. How do you get red lines in a blue display? ... Or are some not blue?
Old 21 Mar 2016, 12:38 pm
LionPT's Avatar
I see I'm not the only one that took the OP as an after market unit.
Old 21 Mar 2016, 12:45 pm
Some of the oval face Chrysler stereo units have a red screen. These were more common in the Sebring hard tops. But one could end up a PT very easily. There's lots of them at the salvage yards.
But yes, we definitely don't have enough to go on here.
Oil cooler lines rwinberg Tech & Performance Forum 0 01 Feb 2016 12:49 am
turbo oil lines TommyBlazin General Turbo Discussions 5 19 May 2014 08:38 pm
VAC lines rice_killing_GT Turbo Performance 11 05 Feb 2012 02:03 pm
vac lines Sparkypt General Turbo Discussions 0 16 Sep 2011 08:44 pm
A/C Lines Leaking (pic inside) Jetta02awp General PT Cruiser Discussions 2 31 Mar 2010 09:09 pm
