SOLVED annoying key in ignition noise
  • 1 Post By quicksilverdon
Old 08 Jun 2016, 12:03 am
044400's Avatar
Default SOLVED annoying key in ignition noise
Every since I obtained this car earlier this year I was greeted with two distinct entry noises. One is the usual factory key-in ignition reminder that is instant.
The mystery and much more annoying noise came through the speakers a few seconds after putting the key in the ignition.
It came from the suspected culprit--Sirius XM receiver. I'm pretty sure it is telling me that my subscription is expired. No more annoying alert now that I unplugged that receiver. Probably could have remedied it by unplugging connector 2 from the rear of the original car stereo too.
Old 08 Jun 2016, 01:10 pm
Default Re: SOLVED annoying key in ignition noise
Hope your cure helps someone else.
044400 likes this.
Old 08 Jun 2016, 01:29 pm
Handy_Cruiser's Avatar
It may have just been a grounding (bonding) issue. If you hook a wire to the chassis of the satellite receiver and then to the chassis of the stereo unit, it might go away.
Steering Noise Solved! Slowrider Tech & Performance Forum 2 14 Sep 2014 07:15 pm
Front end noise solved-hopefully Cajunsim Tech & Performance Forum 1 19 Jun 2009 09:02 am
Annoying headrests? spurvis General PT Cruiser Discussions 9 26 Oct 2005 08:52 pm
Nearly trivial, but annoying Alan Welch General PT Cruiser Discussions 6 19 Nov 2003 08:47 am
