Replaced a Speaker in The RATMOBILE
Like Tree12Likes
  • 4 Post By wingman55
  • 2 Post By CREWZIN
  • 1 Post By NitroPT
  • 1 Post By rckstein
  • 1 Post By NitroPT
  • 2 Post By wingman55
  • 1 Post By wingman55
Old 27 Aug 2016, 10:32 pm
wingman55's Avatar
Default Replaced a Speaker in The RATMOBILE
My wife said the radio started sounding bad so I checked it out and found that the Driver's side front door speaker went South in the 2004 RATMOBILE, so I replaced it with one of the premium speakers I had grabbed from a 2001 in the junkyard a while back.
I was surprised to see that the 2004 Door Speaker is exactly like the speakers in my 2006. For some reason, I thought all Gen I Cruisers had the metal frame speakers.
Of course the connectors are different, as well as the pins themselves. So when I harvest speakers, I always harvest the connectors as well, in case you run into this.
So, this calls for some 'Plug 'n Play' wiring....
Some electrical tape and we're good to go, and, I can always convert back to the other style of speaker/connector in the future if I want to or have to.
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
2004 Limited Edition Platinum Series, Graphite Metallic, Standard Turbo, automatic, RBQ radio with Sirius Radio & 6 CD changer, VentShades, chrome exhaust tip, door spears, grille inserts, door lock pulls, bright pedals and steering wheel spokes. Red spoiler from a donor PT. Known as: "The RATMOBILE" I bought it Apr 28th, 2016 with 62,400 miles on it.
Old 28 Aug 2016, 07:01 am
Default Re: Replaced a Speaker in The RATMOBILE
Nice job ....but you should get yourself a package of Heat Shrink Tubing to keep in your tool chest. It makes a much better covering for any wire fixes. Neater and better insulation from the weather.
You pick a tube larger than the wire. slip it on before soldering the wires. Slip it down over the soldering connection and apply heat. It shrinks over the connection to give a nice tight fit.
NitroPT and wingman55 like this.
Old 28 Aug 2016, 11:32 am
Or a can of Black liquid tape spray Tape
19015167 Black Spray Liquid Tape, 6oz, (1 MIN)
Liquid Tape Spray
To lazy to take a new picture or find the one I already posted about it and using it.
CREWZIN likes this.
Old 28 Aug 2016, 12:31 pm
Handy_Cruiser's Avatar
Congratulation! Those 2001/2002 premium door speaker will sound MUCH better. I did this same mod on my 2005 GT. And afterwards, I could feel the "thump" on my left leg. It's huge difference.
Old 28 Aug 2016, 03:07 pm
rckstein's Avatar
And to go along with the heat shrink kit previously mentioned, pick up a portable butane torch/solderig iron kit:
NitroPT likes this.
Old 28 Aug 2016, 05:13 pm
Ok it time to get a picture... I'll be back.
Old 28 Aug 2016, 05:34 pm
Old 28 Aug 2016, 07:44 pm
wingman55's Avatar
Wow!
Yes, thanks for all the replies.
As far as the heat shrink tubing I literally have a TON of it, and I do have a heat gun. Some day when I decide to replace the passenger side, I will add the heat shrink tubing to both. I guess I was just being lazy.
They were throwing the tubing away at work, and I managed to scarf it up.
Old 28 Aug 2016, 07:59 pm
wingman55's Avatar
Hmm. I initially bought those speakers to put in my '06, but to be honest, if you remember, I tried them, and I liked the sound of the stock speakers better in that car.
However, the '06 has a totally different stereo, so maybe that makes a difference? Also, the rear speakers are in the rear doors in the Gen IIs and THAT makes a huge difference as far as the bass goes. It's VERY noticeable between the two Gens.
In the '04 the new speaker sounds good. Some day, before winter sets in, I will replace the other side and have a matched set. That's when I get to drive it back and forth to work.
I did a similar speaker swap in my Dodge Stratus and it DID make a huge difference. Woofers in the doors and tweeters in the dash as opposed to the standard speakers in the doors.
Handy_Cruiser likes this.
Speaker ?s GtskinnerPt Sound and Security Forum 12 18 May 2013 09:12 am
'02 Rear Right Speaker Out - Speaker Isn't Bad PTBroser Sound and Security Forum 5 19 Mar 2013 08:41 pm
Front Speaker Wiring and Speaker Replacement luttrell1962 Sound and Security Forum 6 12 Oct 2012 01:35 pm
Speaker Help CoolhandPuke Sound and Security Forum 4 14 Jun 2009 02:45 pm
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
