Airbag warning light/alarm - intermittant
  • 1 Post By rsrocket1
Old 08 Nov 2016, 05:36 pm
Default Airbag warning light/alarm - intermittant
I’m having a problem with intermittent illuminating of the airbag warning light and its accompanying chime.
There are two airbag-related lights. One, the “passenger airbag off” light, is next to the emergency flasher switch. The other is the airbag warning light located in the instrument cluster.
Whenever anyone sits in the front passenger seat, the airbag warning lights/sounds intermittently. It’s annoying! But it doesn’t happen when there’s not a passenger sitting in that seat.
So it seems to me that the computer senses someone is sitting there. If the passenger is small/light enough, the passenger airbag is disabled, as it should be. However, regardless of who is sitting there, the airbag warning is activated.
AIRBAG DISABLED / AIRBAG WARNING
Empty front pass. seat NO / NO
Child in front pass. seat YES / INTERMITTANT
Adult in front pass. seat NO / INTERMITTANT
Old 08 Nov 2016, 06:16 pm
LionPT's Avatar
Default Re: Airbag warning light/alarm - intermittant
If I remember right, the passenger airbag sensor is set for 35 or 38lbs.
Old 08 Nov 2016, 10:24 pm
Default Re: Airbag warning light/alarm - intermittent
The weight sensor seems fine and disables the passenger airbag as it should. It's the intermittent airbag warning light and alarm that's the problem. Any time someone is sitting in the front passenger seat, I have to hear that chime over and over and over...
Arrrrrgggg!
Old 17 Jan 2017, 01:08 am
I've the same issue, did you find a solution? I'll be working on it these days, switch unplugged meanwhile.
Old 21 Mar 2017, 03:56 pm
rsrocket1's Avatar
Although the OP is 4 months old and it seems no one looked at this in the past 2 months, I just came across this thread. If this is a Gen 2 PT, it sounds just like the problem I had. The culprit was a dying front right seatbelt latch/sensor. At first it seemed permanent, then for a while it was intermittent, then permanent again. I pulled a replacement from a Gen 2 PT at the junkyard and the problem was fixed. You may need to remove the front passenger seat to get to the fastener holding the seat belt latch on the left side. I needed a T45 socket to remove the rear bolts.
My airbag alarm fix post
NitroPT likes this.
Passenger Airbag warning Mashuu Tech & Performance Forum 19 30 Dec 2017 09:41 am
Airbag warning light worldwideboy Tech & Performance Forum 6 18 Feb 2015 08:12 pm
AIRBAG WARNING LIGHT ON rustyred Tech & Performance Forum 1 06 May 2013 06:36 pm
car wont start. car alarm light and airbag light on trigimon Tech & Performance Forum 7 05 Nov 2010 03:42 pm
Help needed with 2006 PT Airbag Warning Please. ptuser2006 Tech & Performance Forum 2 21 Jul 2010 08:27 pm
