Installing aftermarket front door speakers
Like Tree21Likes
Old 29 Dec 2016, 03:45 pm
Default Installing aftermarket front door speakers
Hi! I just thought I should share some insight on my speaker installation today. I went out and bought two 6 1/2" speakers, knowing that they probably wouldn't fit since the original speakers are oversized 6 3/4". A specialized adapter for the common sized 6 1/2" speakers would take days to ship during this time of year, so I had to manage this on my own.
I used a cut-out part of the old speakers to mount the new speakers and it worked out perfectly!
See the attached pictures. Oops! Ten pictures is maximum. I will post the rest in the first comment.
Old 29 Dec 2016, 03:46 pm
Default Re: Installing aftermarket front door speakers
The last three pictures.
Dazzaman likes this.
Old 29 Dec 2016, 05:11 pm
Handy_Cruiser's Avatar
This is super cool! Thank you for posting it.
If you don't mind, I'm going to post your photos in a row so everyone can see them.
[IMG]http://www.ptcruiserlinks.com/forum/attachments/sound-security-forum/19733d1483044187-installing-aftermarket-front-door-speakers-08-img_1325.jpg
Old 29 Dec 2016, 06:40 pm
Thanks! I guess I didn't know how to make the attached pictures visible
Old 29 Dec 2016, 08:22 pm
rckstein's Avatar
That's quite a MacGyver
This looks like something Handy would have come up with.
Welcome to the forum
You should go to the New Members section and introduce yourself
timalf likes this.
Old 29 Dec 2016, 10:27 pm
wingman55's Avatar
Hi! I just thought I should share some insight on my speaker installation today. I went out and bought two 6 1/2" speakers, knowing that they probably wouldn't fit since the original speakers are oversized 6 3/4". ...................
Beautifully done! Looks exactly like something I would come up with.
Great to see another 'tinkerer' in the bunch.
I do have two comments to make:
1. Make sure that when you drill those speaker frames, you keep ALL the metal filings away from the magnet. If any work their way into the voice coil, your speaker is a goner.
2. Make sure that you keep the speaker wires phased correctly. In other words: + on the old to the + on the new and vice versa. If you don't and you get one speaker reversed the phasing will be out of whack and you will get a diffuse and directionless sound. This also applies to front and rear speaker phasing. An easy way to test them is to listen to a mono recording, or announcer's voice, or use AM radio. If it is correct, the sound will seem to come from dead center and the bass will be reinforced. If it isn't, and the sound is washed-out, and the bass is not strong, try reversing the leads to one speaker, (or both if front to rear is off) or just double-check against a schematic.
Apologies if you already know all this.
Again, great job!
timalf likes this.
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
2004 Limited Edition Platinum Series, Graphite Metallic, Standard Turbo, automatic, RBQ radio with Sirius Radio & 6 CD changer, VentShades, chrome exhaust tip, door spears, grille inserts, door lock pulls, bright pedals and steering wheel spokes. Red spoiler from a donor PT. Known as: "The RATMOBILE" I bought it Apr 28th, 2016 with 62,400 miles on it.
Old 30 Dec 2016, 01:26 pm
Again, great job!
Thanks for the clarifications! They will surely be needed for someone attempting this mod. I tried to measure the output in order to determine plus and minus, but when I failed at that I just soldered it together and as I know how an out of phase speaker sounds, I concluded that my new speakers hand the correct position och plus and minus. This is however not true for all speakers and with your method it is easy to determine if the the sound is in phase
Also, I just marked where I should drill beforehand and removed the new speaker when I was ready to drill And yes! The metal filings is really bad for the speaker
wingman55 likes this.
Old 12 Feb 2017, 03:03 pm
My passenger door speaker is rattling and need to replace. What aftermarket brand and model did you purchase?
Old 14 Feb 2017, 01:32 pm
I bought a Swedish brand called GAS (Great American Sound)
They are in the mid to upper quality range and only costs about $60 for two speakers. You should go for a price point around $70-$90. That will get you a speaker that will handle deep bass as well as the full frequency range. There is one cone + two tweeters per speaker in the ones that I bought.
At the same time I installed a ten year old Pioneer stereo that I had in a BMW 750. I think that the stereo (with bluetooth, but no streaming) set me back about $1300 at the time (with speakers) and installed in my PT it lifted the sound quality enormously! Even with the factory speakers in the back! The guy at the car stereo shop said that the same quality stereo today only costs about $300
Old 21 Mar 2017, 09:21 pm
Why go through all that work. I googled the PT Cruiser speakers, was told 77kick10 was a direct replacement. I found them on line for $64 delivered. Wow, plug and play. Took the door panel off, removed the old speakers, the OEM plug when right into the new speakers, screwed them back in, and bam all done. Sound great too
Front Door Speakers MikeGlosta Sound and Security Forum 6 04 Sep 2016 12:09 pm
WANTED Front Speakers In The Door Hiperguy Classifieds: Want To Buy 1 15 May 2012 02:07 am
Replacing front door speakers evolution1971 Sound and Security Forum 2 15 Feb 2009 11:19 pm
door speakers. best aftermarket brand? pppt03turbo Exterior & Interior Styling 4 23 Dec 2006 12:24 pm
Question after installing speakers in front doors wyzard Sound and Security Forum 3 09 Apr 2004 01:10 am
