Help needed on central locking on 2006 Cruiser
Old 16 Apr 2017, 11:32 am
Default Help needed on central locking on 2006 Cruiser
Hi, I hope some one can make sense of this.
I October 20016 I brought a 2006 Chrysler PT Cruiser RHD 2.4 automatic. The car was only registered in ENGLAND in 2010, I have 1 key which has a built on remote with 4 buttons, Lock/unlock panic & trunk release.
None of my central locking works, the panic button works fine, and when I press the lock button it arms the alarm and flashes the indicators, and when I press the unlock button it de arms the alarm and flashes the indicators, but none of it locks or unlocks the doors, even the two lock toggle switches on the two front doors do nothing. I have checked the fuse, and made sure power is going to the fuse. I can not find a wiring diagram for the 2006 face lift model.
Can anyone please tell me where to check next, as the RKE is not in the same place in the 2006 as it is in my 2001 model
Yours
Jason
Old 16 Apr 2017, 12:55 pm
LionPT's Avatar
Default Re: Help needed on central locking on 2006 Cruiser
When I got 2006 only the front doors looked, the other 3 were broken.
I checked for voltage & couldn't find any at the solenoid. I took a chance & spent $8 on a drivers rear door solenoid. When it came in I tested it on the car battery & it worked (I never thought to test the old one before I bought it). Once I got that one working, I bought the passenger rear door & the hatch.
So, I guess I'm saying...pull 1 of the solenoids out from a door, hook 2 alligator clips to it & touch 1 to each side of the battery. One wire will pull it in, switch wires & it should pop back out.
Old 16 Apr 2017, 05:54 pm
_PTGT03's Avatar
Yours
Jason
alldatadiy will carry the wiring diagrams for the 2006 model, with provisions in the diagrams for export market modifications
Old 17 Apr 2017, 03:00 am
Thanks for all of your info
The next step is to test the central locking activators, but my big wonder is, how come I have a panic button on my key fob and it works, all of the other face lift models I looked at before I brought this one did not have a panic button??
On my 2001 Cruiser I had problem with the central locking, and it was the RKE module so I just changed that, but on the 2006 no single RKE.
Also on the 2 front doors, the locking module is built in to the catch, how do you test that?
Cheers
Jason
Old 17 Apr 2017, 07:59 am
LionPT's Avatar
Do any of the locks work when you push the button on the door from the inside.
All you need to check is a rear door, those are the easiest.
Old 17 Apr 2017, 08:16 am
Hi if you push down or pull up the lock plunger by hand it will lock, but none of the locks work electricly
Central locking problem. NZbling General PT Cruiser Discussions 9 07 Aug 2014 05:49 pm
Central Locking fastdel Tech & Performance Forum 1 16 Sep 2009 05:14 pm
central locking key AlexJB Sound and Security Forum 1 18 Jun 2008 08:47 pm
central locking AlexJB General PT Cruiser Discussions 10 05 Jun 2008 11:01 pm
central locking not working alicelaura Sound and Security Forum 4 12 Jul 2007 02:28 pm
