What is the stealership smoking? (Key issues)
Like Tree9Likes
  #11 (permalink)
Old 06 Oct 2017, 01:32 pm
Default Re: What is the stealership smoking? (Key issues)
Originally Posted by rob302 View Post
Ditto .....
  #12 (permalink)
Old 06 Oct 2017, 02:10 pm
Well, I called the stealership and the locksmith, but believe it or not the locksmith was more expensive. And Walmart said they couldnt do it. So I figured the dealership would have more specific model experience in case something didnt go right, and cost less. Guess I was wrong.
Jeremy
03 PT GT Inferno red Auto
95 Caprice wagon LT1
69 Barracuda 440 4bbl
plus a long list of vehicular toys
  #13 (permalink)
Old 06 Oct 2017, 02:20 pm
I would suggest calling different locksmith's. Some might have better access to the information required to do the job.
Handy_Cruiser likes this.
  #14 (permalink)
Old 06 Oct 2017, 02:29 pm
No, im actually going to call the locksmith again, hes never touched the car. Its the dealership that cant perform the task.
Jeremy
  #15 (permalink)
Old 06 Oct 2017, 02:40 pm
Here is one locksmith in the link below that can do the job with the codes for Pt Cruisers.
PT-Cruiser Car Key | Lost or Broken Car Key | 24hr Automotive Locksmith
  #16 (permalink)
Old 06 Oct 2017, 03:19 pm
rckstein's Avatar
Do you only have 1 dealership in your area?
If not, I would find another dealership to deal with
I just called my local dealership, that I deal with all the time, and they can do it, cut the key and program it, from the vehicle VIN.
The dealership you've contacted sounds like they don't know what they're doing.
'06 Touring Edition NA Automatic
157k Miles / Electric Blue Pearl
USMC '82 - '93
  #17 (permalink)
Old 06 Oct 2017, 03:59 pm
I would just hide the good key under the stering wheel trin and have copys made without the chip
With key hiden under trim skim is read and auto runs normal
JoeX likes this.
  #18 (permalink)
Old 06 Oct 2017, 05:44 pm
And they even told her that the key they cut but failed to program... she'd better not even use it for a backup just to open the door, they said not to use it at all!
Jeremy
  #19 (permalink)
Old 06 Oct 2017, 05:48 pm
Absolutely! I was thinking about this plan too, I was going to snoop around and figure out how close to the ignition the key has to be.
Jeremy
  #20 (permalink)
Old 06 Oct 2017, 05:53 pm
Handy_Cruiser's Avatar
That's an easy trick on a 1st Gen PT.
Just have two copies of the original key made on regular non-Sentry blanks. Then removed the cover from the steering column and use zip ties to secure the original key to the SKIM near the ring that goes around the ignition.
You can also take the SKIM loose, zip tie the Sentry key to the ring on the SKIM, plug the SKIM back in and hide it inside the dash.
Timing belt replacement at the stealership--$1600? Really? Studeguy General PT Cruiser Discussions 22 31 Dec 2015 12:44 am
GT PTC smoking..... DJSELLERS General PT Cruiser Discussions 10 07 Nov 2015 11:50 pm
Smoking Greginnc2014 Tech & Performance Forum 17 30 Dec 2014 04:52 pm
Heavy Smoking... Sbehm90 General Turbo Discussions 9 08 Nov 2012 12:12 am
Starter Smoking Swelve Tech & Performance Forum 4 14 Jan 2011 12:04 pm
