Help! 2006 Limited aftermarket stereo replacement
Old 08 Oct 2017, 02:44 pm
Default Help! 2006 Limited aftermarket stereo replacement
OK, I need a bit of help. I've been searching the forum for over an hour and can't find a definite answer. I'm looking to replace the stock stereo with an aftermarket one. The stock is the REF. Do I need to use a canbus adapter harness or is there another way? I don't have navigation, backup camera or anything else like that if that helps.
2006 Limited n/a
Old 08 Oct 2017, 03:16 pm
Handy_Cruiser's Avatar
Default Re: Help! 2006 Limited aftermarket stereo replacement
The only issue is going to be power for the stereo.
If you go to this webpage at Crutchfield, you can read about it.
https://www.crutchfield.com/Car/outfitmycar/mycar.aspx
The adapter for my 2007 PT is this one:
https://www.amazon.com/Axxess-XSVI-6...ords=xsvi-6502
The antenna adapter is this one:
https://www.amazon.com/Metra-40-CR10...ords=xsvi-6502
There's a thousand bezel adapters. This one's got a cubbie.
https://www.amazon.com/Metra-99-6507...47515WDSN8JCXW
Old 14 Nov 2017, 01:22 pm
Great advice all around and I agree with an extra bit of information. That cubby adapter is great except for the clip-in front bezel.
I bought all the same pieces you mentioned and everything works great. But I needed to actually glue that bezel piece in place because it's only held in with (2) tiny clips.
Chris Faulk
2006 Limited PT Cruiser
88,000 miles
Who has installed an aftermarket stereo? PTnoob Sound and Security Forum 26 07 Sep 2017 06:51 pm
2006 Aftermarket Stereo Installation MissMegan Sound and Security Forum 2 30 Mar 2010 04:31 pm
Wiring Mopar Sub to aftermarket stereo Bevynn Sound and Security Forum 6 21 Mar 2010 04:36 pm
06 aftermarket stereo problems mattwild Sound and Security Forum 0 16 Dec 2009 11:12 am
Best Aftermarket Stereo? jimmmhare Interior Accessories Forum 6 17 May 2007 07:02 am
