Where to ground sub amp
Like Tree2Likes
  • 1 Post By Birdman
  • 1 Post By ShakeMyShifter99
Old 07 Mar 2018, 03:37 pm
KalebSikora's Avatar
Default Where to ground sub amp
I have installed a subwoofer and an amp in the trunk and I'm having a hard time finding a bolt for my ground wire. Is there any pre-made hole to the bare metal like under the front seat or will I have to drill a new hole? If I do have to drill, how and where would I go about doing that?
Old 07 Mar 2018, 03:54 pm
Handy_Cruiser's Avatar
Default Re: Where to ground sub amp
The silver cargo rings in the back screw into the chassis on the bottom rings and into metal brackets that are bolted to the chassis on the side rings. These should provide a pretty good ground. And one of the large Torx-head seat belt bolts should provide an excellent ground.
Old 07 Mar 2018, 04:04 pm
Oh sweet I'll have to check that out. I noticed those actually but wasn't too sure on how to remove the trim. Thanks!
Old 07 Mar 2018, 06:02 pm
JonN's Avatar
What did you decide on for a system?
BIG RED '01 LE 193K and counting!
Vision Cross 16x7 Rims, 205/55/16 , Painted Calipers, Spoiler, CAI, Pioneer DEH-64BT head unit, NEW Skar SKv2 200.4 amplifier 2 RF P2D2 12's, RF P1T-S Tweets, RF PPS4-6 Mids, RF 6x8"s, AudioControl 24XS crossover/line driver
Newest Car
2016 Jeep Patriot Sport 2.4L 6 speed auto 92k
NRS brakes and energy suspension bushings
Pioneer DEH-X9600BT head unit, B² Rage 1200.6 Amp, 4 JBL GX963 6x9's, 2 Skar VVXv3-12's. 6 Channel AudioControl Matrix Plus Line Driver. Stinger fan. ACR1 Bass knob
#LoudLife
Both powered by Mobil1 oil and K&N filters
Old 16 Mar 2018, 02:03 pm
I used to compete in SPL car audio competition on a national level
https://www.termpro.com/asp/competit...38893&Method=1
Competitor Stats: Aaron Bird
Competitor Stats: Team Darkside
(I got out of it in 2008)... my biggest build was 2 18" dual voice coil Inhuman hand built subs on 10,000 watts in a 30 cubic foot sub box built in my 89 Caravan running 3 runs each power and ground of 2/0 welding cable to aluminum buss bars..... I also used to install for Best Buy Electronics here in Calgary... I say all this to back up my knowledge and not to show off.
The best ground you can get is direct to the battery. And make sure the ground cable is at least the same gauge as the power cable...or better use a bigger gauge for the ground. It lowers the resistance in the circuit and will extend the life of your amp. Also make sure your connections are soldered where possible.
As far as the ground, to the battery and bigger than the power cable...the 2 best pieces of advice I can offer to anyone.
NitroPT likes this.
Old 16 Mar 2018, 02:47 pm
If any ground is used for an Amplifier other then the direct battery you must make sure the the *grounds are good between the frame and body and engine and frame and engine and body . Don't assume that even a single or grouping of factory harness grounding wires has the best continuity. Most times the addition of *added braided ground straps are needed to insure best grounding of all electrical components on most every platform when adding upgraded stereo components like amplifiers or even other electrical projects.
Old 28 Mar 2018, 04:44 am
If you can, run a ground of equal or greater size than the power wire all the way back to the battery. That is 100% the BEST option but it certainly isn't always practical. However, I understand that wire can be expensive and bulky. If you choose not to run it back to the battery, you can ground to metal in the trunk. (This is the method I chose for my fairly modest system) There are a few things to consider when grounding to the trunk.
1) Location.
This one of the most important parts of making your ground. You need to find a place where the metal isn't super thin and has a large contact are with the rest of the body. We need the circuit to have as little resistance as possible.
2) Contact.
You'll need good contact between your ring terminal and the body of the car. Ground to a flat, clean spot if possible. I always like to drill my ground, sand the burrs smooth and wire-wheel or sand the heck outta the area the ring will be touching. Afterwards, I spray satin clear coat on the top and bottom to try and prevent rust.
3) Safety.
Make sure nothing will be getting anywhere near shorting this sucker out. Use the proper fuses and always heat-shrink your connections.
Hope I could help at least a little!
-Zack
Handy_Cruiser likes this.
Silver 2001 “FreeT Cruiser” Base. Dead stock.
1/4 mile: <30 sec
0-60: eventually
I love my car and Cruiser culture.
Old 28 Mar 2018, 08:55 am
^^That's all a great response but if the response i first posted is not first done then using the trunk area will cause grounding issues when using an high output amplifier that needs the best positive and ground connections..
This is why most higher end stereo shop do not ground in the trunk as described without first install a grounding kit.
But members can do what they think is best!
where to ground amp bhunt41 Sound and Security Forum 5 29 Aug 2011 03:14 pm
Ground Wires? psychejim6077 Tech & Performance Forum 10 10 Jan 2011 10:04 am
Ground Effects Windancer Exterior Accessories Forum 2 28 May 2007 08:01 pm
where to ground my amp CruiserDan Sound and Security Forum 6 17 Dec 2004 03:43 pm
Ground strap mcruz General PT Cruiser Discussions 8 26 Dec 2003 09:36 pm
