Keyfobs stopped working.
  #21 (permalink)
Old 15 Apr 2018, 03:30 pm
LionPT's Avatar
Default Re: Keyfobs stopped working.
Originally Posted by Nevermore673 View Post
Lion, the correct wiring harness that comes with the data module IS plug & play. As for the small square plug, no, there is nowhere for it to plug into. However, when I put the factory unit back in, I did plug both plugs in (including the small square one) but my key fobs still didn't work. So the problem at this point isn't the stereo, or the keys themselves.. it has to be something else.. maybe the module that receives the signal from the keyfobs?
Does anyone know a way to reset that other than paying the dealership to "reprogram" it?
So then all the pics with the wires cut off are misleading, your saying that there is a plug on both sides of the harness & you don't have to cut/splice any wires at all..??
  #22 (permalink)
Old 15 Apr 2018, 04:03 pm
rckstein's Avatar
This is the wiring diagram for the PAC C2R-CHY4:
https://www.manualslib.com/manual/11...-C2r-Chy4.html
But since you have reinstalled the stock stereo, can you please post a pic of the actual part that you had installed and not a stock photo from the internet?
'06 Touring Edition NA Automatic
160k Miles / Electric Blue Pearl
USMC '82 - '93
  #23 (permalink)
Old 04 May 2018, 01:18 am
Update?
And with the clock going out at the same time, I'm thinking fuse.
# 17 looks like one to check, under the hood: "Clock, central locking control module, power steering control module" (for 2005+ or 2006+).
  #24 (permalink)
Old 04 May 2018, 10:32 am
Originally Posted by Spaz View Post
Update?
Fuse #17 also goes to the key remote module. If fuse #17 is replaced and still not working check fuse#8. If there was a short it might have taken out both fuses.
Tags
keyfob, locks, remote, stereo
FOB stopped working? ceil99 General PT Cruiser Discussions 2 06 Aug 2015 09:53 am
AC stopped working realized Tech & Performance Forum 2 22 Jun 2011 06:06 pm
key fob stopped working twotone General PT Cruiser Discussions 10 17 Jun 2011 05:47 pm
My ac stopped working. Help!!! salena Tech & Performance Forum 3 14 Oct 2009 10:56 pm
