aftermarket radio
  #11 (permalink)
Old 04 Jul 2018, 12:00 pm
markeele's Avatar
Default Re: aftermarket radio
Originally Posted by KalebSikora View Post
On the harness you need to match up all the wires correctly. The OEM wires should say what they are. You need to crimp them together accordingly. I'm assuming if you did all that correctly it's possible that you forgot to connect the remote turn on. The PT doesn't have this wire from factory, so you have to tap into the accessory wire and connect that to the blue wire with the white strip (also known as the remote turn on wire) on the harness you bought.
This accessory wire connects to the front cigarette lighter in front of the shifter. You don't need to remove the whole center console to tap into that wire. I personally used a t-tap and ran that wire to the remote turn on wire on the harness. If you don't know what t-taps are or where to get them, this is an example of the same t-taps I used. They work great.
Here is an example of my car where I t-tapped into that wire:
What about the orange wire on my harness i didnt connect it to anything either, it says dimmer on the wiring harness that i bought.
  #12 (permalink)
Old 05 Jul 2018, 09:04 pm
KalebSikora's Avatar
All you need to do is plug in that metra harness into the factory harness, then crimp the wires from your radio harness to the metra harness. Here is an image of mine:
1. My metra harness is plugged into the factory harness.
2. Most of the wires on that metra harness are unused and therefore capped off.
3. The orange wire you inquired about just connects to the orange wire from your radio harness.
  #13 (permalink)
Old 16 Jul 2019, 06:13 pm
Send a message via Yahoo to partyd
if you look in the new harness the red wire its the ignition, 2006 and up pt cruisers don't have ignition wire because the work with data, you have to get ignition for your new radio from a different source,
like the cigarette lighter or the fuse box
2008 Pt cruiser Touring
2004 Pt Cruiser GT
2004 Chrysler 300M
2008 Chrysler Pacifica awd
Why would vent selector change the radio station? (aftermarket radio) Spaz Sound and Security Forum 11 08 May 2016 01:10 am
aftermarket radio in 06 06OregonCruiser Sound and Security Forum 13 29 Apr 2015 10:06 pm
aftermarket radio install berk3066 Sound and Security Forum 5 28 Dec 2010 05:07 pm
Aftermarket Radio Install DaJ4ck3L Sound and Security Forum 8 18 Aug 2010 04:59 pm
Aftermarket radio help gmariconda Sound and Security Forum 1 05 Jan 2010 04:01 pm
