One speaker not firing
Old 17 Nov 2018, 04:07 pm
Macgyverman1123's Avatar
Default One speaker not firing
Hey guys!!
The other day, I was playing around with the fade and balance and I noticed the speaker in the driver door is not firing. All the other 5 are, both rear pillar, both dash tweeters and the passenger door are working. I know it's not blown, I never listen at lound volumes or anything and none of the other speakers are having any symptoms of that.
I'm going to pull off the door panel and look for loose connectors. Anything else I should be looking for?
Old 17 Nov 2018, 08:23 pm
LionPT's Avatar
Default Re: One speaker not firing
I've had problems with my drivers door speaker...
It didn't work when I bought car, I replaced it & about a year later it stopped working.
This time it was a broken speaker connector (at the cone), so I replaced it again but taped it up pretty good.
Old 17 Nov 2018, 08:44 pm
Well, I took the door panel off. There was some.minor rust/corrosion on the contacts, but nothing was loose or broken. The cone and voice coil appears to be intact, no rips/tears and no burnt resin smell. Maybe I'll swap it with the passenger side one and try it again.
Any ideas?
Old 17 Nov 2018, 08:50 pm
rckstein's Avatar
Any ideas?
That's what I would try, switching to a known good working speaker
'06 Touring Edition NA Automatic
164k Miles / Electric Blue Pearl
USMC '82 - '93
Old 17 Nov 2018, 10:46 pm
I'm gonna try the speaker swap. If it ends up being the speaker, where can I find an oem replacement? I want a matched system but I'm not spending the money to put in a good system right now.
If it is the wiring, how should I go about repairing it?
Old 18 Nov 2018, 07:45 am
If another speaker doesn't work, I'd suggest checking the wires where they come through the door. Just use a DVM set on ohms and probe the wires. You might just find a broken wire. You'll have to take the plastic casing loose between the frame and the door.
Hey, hey I wanna be a rock star.
Old 19 Dec 2018, 07:42 pm
rob302's Avatar
Last night I was fixing my passenger door speaker. Wasn't working because the previous owner was incompetently using butt connectors in the dash.
Fixed the speaker and then rewired the power port so I can charge my phone with the car off.
Don't overlook the wiring in the dash.
Back firing loomex General PT Cruiser Discussions 13 09 Oct 2018 05:15 pm
04 not firing on 1 and 4 ccoffey3131 Tech & Performance Forum 7 29 May 2014 11:36 am
Not Firing Koseck Tech & Performance Forum 3 20 May 2013 02:45 am
Front Speaker Wiring and Speaker Replacement luttrell1962 Sound and Security Forum 6 12 Oct 2012 01:35 pm
Miss firing code cyl 4 devil9 Tech & Performance Forum 3 04 Jun 2010 09:36 am
