Looking for new, direct replacement speakers
Like Tree4Likes
Old 22 Jan 2019, 01:56 am
Gkon's Avatar
Default Looking for new, direct replacement speakers
Hi everybody!
Been a while since I posted. Moved to a new state last April, took a few months to settle in, and now have been working on my motorcycle project mostly. However, spring is coming, and I want to give some TLC to my PT.
Can anyone recommend direct replacement speakers (both front door speakers, both tweeters in the dash, and both rear speakers) for my 2002 PT Limited Edition?
I want something that will screw right in and give me good sound.
I am using the stock PT radio/casette/AM-FM radio.
No, I do not want to change out the radio.
No, I do not want to install a power amp, or bass cabinet.
I just want direct replacement speakers that will give me decent sound.
Sorry, I haven't done a search for previous posts on the subject. I figured I'd just ask and start a new conversation.
Thanks!
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
Old 22 Jan 2019, 08:20 am
Default Re: Looking for new, direct replacement speakers
You might try Crutchfield, Kon. 844-584-1114 Or crutchfield.com
Gkon likes this.
Old 22 Jan 2019, 01:04 pm
JonN's Avatar
I have these in front doors
https://www.amazon.com/Rockford-Fosg...8180113&sr=8-1
I have these in the rear
https://www.amazon.com/Rockford-R168...8180180&sr=8-4
And these tweeters in the dash
https://www.amazon.com/Rockford-Fosg...s%2C140&sr=8-2
Never had a problem with any of them and I have a complete aftermarket set-up
Gkon likes this.
2016 Jeep Patriot Sport 2.4L 6 speed auto 97k
NRS brakes and energy suspension bushings
Pioneer DEH-X9600BT head unit, Bē Rage 1200.6 Amp, 4 JBL GX963 6x9's, 2 Skar VVXv3-12's. 6 Channel AudioControl Matrix Plus Line Driver. Stinger fan. ACR1 Bass knob
#LoudLife
Both powered by Mobil1 oil and K&N filters
Old 22 Jan 2019, 04:39 pm
Gkon's Avatar
Thanks Chuck! Will do!
Old 22 Jan 2019, 04:40 pm
Gkon's Avatar
Thanks! I'll check them out.
Old 28 Jan 2019, 02:51 pm
Gkon's Avatar
Hiya Chuzz. Unfortunately, Crutchfield has no direct replacement for my car.
Old 28 Jan 2019, 02:53 pm
Gkon's Avatar
JonN,
Did you need to do any mods to mount there or were they a direct mount?
Also, what are the square "boxes" that come with the tweeters?
Old 28 Jan 2019, 03:29 pm
Fk5 Fk5 is offline
Originally Posted by Gkon View Post
JonN,
Those should be the "high-pass crossover." I haven't done much car audio lately, but if it is like the old days, those are to keep from sendign heavy bass to those tiny speakers that can't handle it. The wubwoofer should have something similar to keep the highs from getting there. Some of them are tunable, so you can pick the cutoff. When everybody started getting those 3-in-1 speakers they were less necessary, but actual component speakers need some kind of crossover to make sure the tweeters were not gettign too much bass and the woofers too much treble. Infinity kept pushing the components well after most
3-way https://images.crutchfieldonline.com...6DSC6904-F.jpg
Component https://www.crutchfield.com/p_108PER...QaAiM1EALw_wcB
2003 GT 5 speed
162,000 miles
Old 28 Jan 2019, 10:31 pm
What??
I see plenty listed for an 02. Except the tweeters, but I bet they do have them.
03 Turbo AutoStick
107K
Cranny
Old 29 Jan 2019, 01:02 pm
smarq17's Avatar
Something different to consider...
In my '03 Limited, I have 6.5 Crunch component mid-woofers in the door. They fit with no extra work at all once you buy the adapters.
Instead of using the included component 1" tweeters, which would have required an adapter to install in the dash location, I decided to buy some 3.5" Crunch 2-way coaxial speakers. All due to me not wanting to do any cutting in the door panel for the component tweeters and also, I was simply unable to find any adapters to install the component tweeters in the dash location. I also used the included component crossover to run the 3.5" as de-facto tweeters. So this was actually, for me at least, the easier way to upgrade.
The dash installation was a bit tricky though, since I needed to widen the speaker opening by shaving some plastic to make the 3.5" speakers fit correctly. A dremel does this easy enough but the plastic shavings are a pain to clean out from behind and inside the dash. Once I shaved enough, they drop in smoothly and I can even use the OE screw holes too.
The only noticeable (not very though) is the dash cover is slightly raised in the area over the speakers due to the coaxial tweeters. Not a big deal since apparently I'm the only that has noticed that "bump". I was considering going back and widening the space just a little more to make the installation more flush, but decided against it due to it being such a minor imperfection.
BTW, I did this installation over a year ago and am still seeing plastic shavings whenever I take out my floormats to clean. So beware.
Everything can be found and bought on eBay (of course right?), except the 3.5" coaxials which for some reason are rare and over-priced there. I bought those online at Sonic Electronix. Might be able to find the 3.5" on eBay for less than $20 if your timing is lucky though.
The sound was an amazing difference from stock and the highs off the windshield are noticeably apparent. I was thinking of using a similar setup for the rear speakers since there I have 5x7" Crunch 2-ways running straight forward and still have the extra pair of tweeters. So far I'm happy with those speakers as is so not fiddling with them - for now.
I'm sure you will, if not already, figure out your own setup.
Two wrongs don't make a right, but they make a good excuse.
Would a $30 pair of Kenwood speakers be an improvement over stock speakers? bladerunner6 Sound and Security Forum 9 03 Feb 2012 03:31 pm
Is this a direct fit? Jimmy2011 Turbo Performance 5 05 Oct 2011 08:41 am
Replacement Speakers SCBluePT Sound and Security Forum 5 04 Aug 2011 09:35 pm
replacement door and pillar speakers ValAir Sound and Security Forum 21 01 Dec 2010 08:08 am
Which speakers to swap when upgrading speakers/sub/headunit? cnjvh Sound and Security Forum 1 24 Apr 2010 12:56 am
