Ignition Key and Radio
Like Tree7Likes
  • 1 Post By rckstein
  • 2 Post By the3dgm
  • 4 Post By rckstein
Old 25 Mar 2019, 04:33 pm
Default Ignition Key and Radio
Coming back from taking pictures of my '04 Dream Cruiser today the radio quit. At first I thought I may have blown a fuse and it was getting no power, no sound or display.
When I got home and went to shut the car off, as I grabbed the key the radio display came on and off a few times. I tapped the key a few times and the display would show for a second then back off. I turned off the ignition and moved the steering wheel to different positions then turned the key to on at each stop, near the top of it's travel range the display came on and stayed on, but, no sound. . . senior moment. . . I turned up the volume and all was right again.
So, what am I dealing with? Wires, ground, ignition switch? Thoughts!
Old 25 Mar 2019, 04:45 pm
rckstein's Avatar
Default Re: Ignition Key and Radio
This seems to be an issue that plagues the Gen1, read these threads:
Radio display not working? Read this
Horn and Radio Screen Intermittent?
the3dgm likes this.
Old 25 Mar 2019, 05:10 pm
Thanks, Rick! That seems to be the problem I'm having. I'll check out the ground first.
Old 25 Mar 2019, 05:16 pm
rckstein's Avatar
It was your own fault and that's what you get for getting your PT recently detailed
Some other part of your PT is now feeling neglected and wants some attention, too
OEM CD/Radio to Ignition Switch problem harry General PT Cruiser Discussions 4 05 Feb 2018 09:14 am
Radio Not Working After Ignition Actuator Replacement jeremysaal Tech & Performance Forum 5 17 Nov 2015 02:09 pm
radio doesnt turn on with ignition sk8amp4 Tech & Performance Forum 3 22 Jun 2015 07:32 am
Radio won't turn on when ignition is set to acc Perpetrator Sound and Security Forum 9 10 Mar 2011 05:48 pm
Aftermarket radio wont turn on and off with ignition Samson Sound and Security Forum 8 23 Jan 2010 12:09 am
