New CD Player;Power But No Power?
Old 30 Mar 2019, 04:00 pm
SpaceMouse's Avatar
Default New CD Player;Power But No Power?
So I got a new CD player and this mounting kit:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Wired up the harness to the harness that came with the CD player (yes I did this correctly, I'm an Electronics Fabrication Technician at a major government R&D lab). When I pulled the OEM CD player I was a bit alarmed to see that there are TWO connectors on the back end; the installation kit came with only one connector, and it matched the larger of the two sockets on the back of the OEM unit. "Okay", I tried to convince myself, "the second connector is just for the CANBUS system or something, it'll be okay".
It isn't.
The new CD player won't power up. What's bizarre, however, is that if you hit the eject button you can hear the CD mechanism spin up, and if you insert a CD, the unit will swallow it (but won't spin up, to say nothing of playing it). Hitting the eject button has the unit spitting the CD out as one would expect. So the mechanicals have power, it seems, but the electronics appear to be dead as a doornail- no lights, no sound, no indication that anything at all is happening.
So... is there a handy pinout of the two connectors that connect to the back of the unit, or an aftermarket wiring harness that includes BOTH connectors (if that's what's necessary)?
Thanks!
Old 30 Mar 2019, 06:14 pm
SpaceMouse's Avatar
Default Re: New CD Player;Power But No Power?
Never mind. I think I've got this figured out. The second harness connector isn't necessary, but a switched power source is. And the way the radio is wired into the CANBUS system, it's, well, non-standard. I could pull the center console and tap into the switched power source for the cigarette lighter (and possibly still have problems with the system recognizing the radio), or drop $60 for an adapter harness from Crutchfield.
I'm doing the latter.
Whee.
Old 16 Jul 2019, 06:06 pm
Send a message via Yahoo to partyd
Yes there is no ignition wire in the factory harness just take power from the cigarette lighter or run a cable to the fuse box this is only for the 2006 and up pt cruisers
2008 Pt cruiser Touring
2004 Pt Cruiser GT
2004 Chrysler 300M
2008 Chrysler Pacifica awd
Power Seat swap on 2008 PT Cruiser Base and no power victort13 General PT Cruiser Discussions 4 07 Jan 2017 08:35 pm
2006 PT Cruiser no power to power seat paradyne64 General PT Cruiser Discussions 5 29 Dec 2016 02:54 am
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
FIXED: No power to power sockets, front or rear InTheBlack Tech & Performance Forum 2 11 Jan 2011 11:12 pm
How to get power to my mp3 player & other concerns Doktor X Sound and Security Forum 3 29 Jul 2005 10:38 pm
