where is a good place inthe hatch area to ground an amp mounted to either the seat back or a box that will be on the right side?
Dan |
While any solid point on the body will be a ground, I'd consider a dedicated ground cable. Read the threads on hypergrounds. The cost and hassle of a few feet of wire should pay off with better sound, which is what the whole operation is about, right?
2004 Dark Plum Base with windows tinted, cabin filter, silencers removed, fog lights, 18\'s, all Red taillights, Blaine\'s struts, modesty cover, color-matched center dash, 06 rear bumper |
ground is more important that power lead, use the same size cable for both. shortest ground is best. remove rear side panel, scuff up an area, drill hole, attach ground to sheet metal screw, paint to prevent rust.
www.cardomain.com/id/rallydrock |
i have to take a look in the car some time tomorrow , where did everyone else ground em?
Dan
<font color=\"blue\">Patriot Blue</font id=\"blue\"> 02 5-Spd |
mine is under the driver's seat and grounded to the emergency brake bolt
i used the bolt that holds down the i guess ring where the rear seats lock onto, just sanded the bold and washer and tightend it back to spec. and re installed the plastic shroud and all is good.
Dan
good choice, dan
| Crappy Ground Wire | Mean Green | General Turbo Discussions | 2 | 31 Dec 2004 09:56 pm |
| Hyper Grounding | Mean Green | Turbo Performance | 25 | 19 Nov 2004 02:57 pm |
| Added ground wire=better performance? | littleblueGT | Turbo Performance | 17 | 06 Nov 2004 10:02 pm |
| OEM Ground Effects | 1lowufo | Exterior Accessories Forum | 3 | 24 Apr 2004 07:48 pm |
| Customer wants his PT on the ground | tukn20s | Wheels, Tires, Suspension | 17 | 19 Nov 2003 07:59 pm |
