PT Cruiser Forum Car Videos
Car Rims
Stage 1 '05 in an '03?
  #11 (permalink)
Old 15 Sep 2005, 07:35 am
rszappa1 rszappa1 is offline
Give them a call and that is what they will tell you....Remember that is for the turbo pt application...
  #12 (permalink)
Old 15 Sep 2005, 10:39 am
AZ_IceMan AZ_IceMan is offline
Send a message via AIM to AZ_IceMan
Well i am using the NGK copper plugs to clarify, gapped at .033 and that is backed up by AGP turbo, who can vouch for the r & d.[:X]
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
  #13 (permalink)
Old 15 Sep 2005, 11:46 am
wait4me6920 wait4me6920 is offline
Yeah, the copper plugs are the ones I'm talking about... BTW, was going to try the Denso irridium plugs, but the length of the plug was different, shoulder different & shorter, etc... Gave it up and going with the copper V-Powers...
2005 Turbo Lite, Stage 1, Mopar/Borla cat-back exhaust, Eibach swaybars, Bilstein coilovers, 18/8 TSW Montage wheels with 225/40/18 Exclaim UHPs, LED taillights, K & N drop-in & a few other goodies...
  #14 (permalink)
Old 17 Sep 2005, 11:23 am
SuGamer SuGamer is offline
The difference with the 05 is not only the plastic manifold, but the PCM is programmed to take advantage of it. A 05 PCM cannot be adapted to an earlier car because the programming is different because of different sensors (yes, they may look the same but are not).
Like I said in the other thread, a NGK CS rep told a friend one thing, another told him something else. Both AGP and Psi-Fi recommend the NGK's at .028 gap. They have done must research and testing, whereas NGK made their plugs and gapped them to what they thought was ideal. Listen to NGK if you want to, but don't get upset with others because they are getting a smoother idle and more power by using a lower gap. This has been proven already.
  #15 (permalink)
Old 17 Sep 2005, 08:57 pm
Mean Green Mean Green is offline
How has it been proven there is more power? Dyno #'s? Track #'s? Haven't seen any #'s. Just butt dyno talk.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
  #16 (permalink)
Old 18 Sep 2005, 12:20 am
Tom, I understand how you feel. Believe it or not, the stock plugs gapped at .040 always worked well for me as well. But Psi-Fi has dynoed with the NGK's at .028, and that's why they recommend that gap if you up the boost or get a PowerPaq. It's like this; Junior's stock plugs came with a .050 gap. You recommended that I lower the gap to .040 and I did. Where you right? HELL YEAH!!! You couldn't be more right! The power was felt right away. It's kinda the same with the NGK's; the stock gap is not the worst nor the best, just adequate.
  #17 (permalink)
Old 20 Sep 2005, 05:22 pm
Topless in Cali Topless in Cali is offline
I highly doubt S1 for '05 will work on an 03'. I have the early 05 w/ alum intake and my S1 instruction sheet says 235Hp @ 4900 and 275lbs TQ @ 2800RPM. So the difference is in the programming. The plastic manifold will make a difference once you start upping the mods and boost, but I'm not convinced that it would make a lot more power on say an 03 w/S1 and cat-back system. Az, you've got a lot more than that, so I think the manifold will help in the overall power production. Besides, if you go PPQ, the S1 programming is all but irrelavent when it comes to AFR's. Wether or not it is 03 or 05 S1, the programming is altered for even more power!
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
  #18 (permalink)
Old 21 Jan 2006, 08:56 pm
1ptturbo 1ptturbo is offline
Yeah, i know, just wanted so see if i could raise my base numbers a bit, before all the other mods. but if the extra 15lbs of tq are purely because of the manifold, then i am good to go,cause i just put it in.
Are you saying you put an 05' SI in an 03'?
  #19 (permalink)
Old 23 Jan 2006, 12:22 am
PTGT Redman PTGT Redman is offline
03 stock injectors are lower output. In 04 stock GT injectors were the same output as the 03 upgrade injectors. In addition, PCM changes from 04-, like noted above, would make retrofitting an 05 PCM in an 03 unworkable. Better to find someone with an 03 PCM and injectors that they are not using.
Homepage:
  #20 (permalink)
Old 04 Feb 2006, 10:28 am
GR8FLPT GR8FLPT is offline
The difference is 8hp for non late 05's, 10hp for late 05's using the plastic mani. The tunning on the late 05 adds the extra 2 hp.
I got this directly form an engineer who worked on the upgrades to the new GT motor. His thoughts were "do you really think you will noice 2hp gain" He said swap to the plastic mani, it's a cheap & easy way to improve your car.
I did & he was right... but I still want to squeeze out that extra 2hp...[8)]
04 GT 5 spd, S1, Mopar Sways, Eibach springs, Airbox mod, K&N drop-in filter, AGP & AMX hard pipes, debadged, PTeazer grill, bumperette, rollpan, Cowl Induction hood & other assorted painted parts!!!
vB code is On
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
"Stage Turbo Forums" Killed by Mopar hyracer Stage Turbo Kits 20 28 Apr 2005 04:26 pm
Tour de Lance STAGE 13 UPDATED PTRON Non-PT Discussions 1 18 Jul 2004 09:02 pm
Tour de Lance STAGE 7 PTRON Non-PT Discussions 0 10 Jul 2004 07:13 pm
Stage 2 info from SRT-4 site dtbrks Stage Turbo Kits 24 26 Nov 2003 05:24 pm
  Kung fu art of fighting | Cheap Car Insurance | Jokes | Mortgages | Credit Card
