PT Cruiser Forum Car Videos
Car Rims
Stage 1 problems!!!!!
Old 20 Sep 2005, 07:27 pm
ValAir ValAir is offline
Default Stage 1 problems!!!!!
I just got finished installing my stage1 kit and the new plastic upper and lower intake. When i am cruising lets say in second gear and i punch it..........it will go for a quick second and then I get burping and farting.........what the hell is it?????
One frustrated puppy here,
Val
Old 20 Sep 2005, 07:29 pm
AZ_IceMan AZ_IceMan is offline
Send a message via AIM to AZ_IceMan
It is more than likely your plugs and wires. Make sure you have new performance wires and new plugs gapped at around .033 and your problems will disappear. [?]
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
Old 20 Sep 2005, 07:56 pm
Thanks IceMan,
I will run out right now and regap the plugs and see what happens.
I thought everyone gapped the plugs at .40 after putting the S1 on?
I'll regap and get back to you.
thanks,
Val
\'03 GT Black, 5 speed, Chrysler/Borla dual exhaust, Chysler performance air filter, Stage 1 kit, Plastic Intake, Chrysler B.O.V.,
Magnecore wires.
Old 20 Sep 2005, 08:48 pm
IceMan,
Thanks very much, I regapped the plugs to right around .33 and problem solved![?] [^] Big Smile!
and a big HOLY SH*T does this baby move out!
Now, as far as wires, plugs down the road, what is recommended?
Magnacore wires? (which ones) and what plugs.
Thanks again,
Val
Magnecore wires.
Old 21 Sep 2005, 09:18 pm
Another satisfied customer. [8]
Old 21 Sep 2005, 09:21 pm
I heard the magnecor's are good. the 8.5mm ones the mopars are ok too. I personally have the AGP ones. They are heat shielded and custom fitted for our engines and fit better than most other sets i have seen because wires 2-3 are trimmed with an L boot so they fit better and won't rub against anything, like my 3 wire used to all the time on the throttle cable. You can find the wires on AGP's site at AGPturbo. com under pt cruiser stuff. Comes with plugs and remachined plugs for better combustion. But I'm glad i could help.
vB code is On
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
Tour de Lance STAGE 13 UPDATED PTRON Non-PT Discussions 1 18 Jul 2004 09:02 pm
Tour de Lance STAGE 7 PTRON Non-PT Discussions 0 10 Jul 2004 07:13 pm
STAGE 1 PROBLEMS!!!! EDGAR TAMAYO Stage Turbo Kits 4 06 Apr 2004 01:25 am
Stage 2 info from SRT-4 site dtbrks Stage Turbo Kits 24 26 Nov 2003 05:24 pm
  Loans | Loans | Debt Consolidation | Loans | Libros
