PT Cruiser Forum Car Videos
Car Rims
Stage 1 problem solved
Old 20 Sep 2005, 09:24 pm
ValAir ValAir is offline
Default Stage 1 problem solved
OK, Now that my S1 problems are fixed thanks to IceMan, I am going to act retarded and welcome myself to the S1 club!!!!![?] Or should it be called the LEAD FOOT club?
WOW, that is all I have to say right now. I still have to drive it more (I only took it out for about a mile after the plug re-gap).
I have an opinion on the plastic intake that I put on with my s1. I emailed Tommy and told him about this and would like to know if anyone else has run into this. I have an '03, replaced the stock intake with the plastic one and then had to re-gap the plugs because of the problem I was having..........I couldn't get access to the 2nd from left plug hole. I had to unbolt the intake in order to get to it. Also, the oil dipstick does not attach to the new intake. Other than these 2 things.........I am happy, well except for the amount of money I am going to be spending on gas from stompin on it all the time.
Val
Old 21 Sep 2005, 10:59 am
Culprat Culprat is offline
Welcome,and happy stomping.
culprat@sbcglobal.net
Old 21 Sep 2005, 12:35 pm
Mean Green Mean Green is offline
Welcome to the fun. Others have secured the dipstick with a L bracket.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 21 Sep 2005, 02:29 pm
Cal Cruzer Cal Cruzer is offline
The plug access to that one plug is the downside to the plastic intake. I think I read about someone grinding enough clearance on it so they didn't have to remove the upper but I cannot confirm this is possible. Upper removal is just part of the gameplan ona plastic intake car.
Also, do something soon to attach the dipstick tube. One unluck soul didn't and he cracked the tube and had a heck of a time R&R-ing it.
Old 21 Sep 2005, 09:23 pm
AZ_IceMan AZ_IceMan is offline
Send a message via AIM to AZ_IceMan
[^] Glad my prescription worked.
<div align=\"right\"><h2><b><i>Can we say Sleeper?</i></b></h2></div id=\"right\"><div align=\"right\"> </div id=\"right\">
Old 22 Oct 2005, 12:08 pm
ElectricBlueGT ElectricBlueGT is offline
To access the plugs on a PT with the turbo plastic manifold, all you need are two universal joint socket adapters connected in series with the spark plug socket. This has been performed and verified by several PT owners.
Scott
\"If you choose not to decide, you still have made a choice.\"
Old 25 Oct 2005, 05:02 pm
Topless in Cali Topless in Cali is offline
Scott
Or you can get the sparkplug socket with the universal joint already attached and then a second universal joint socket adapater right on top of that.
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
Old 06 Nov 2005, 12:26 pm
GR8FLPT GR8FLPT is offline
you can carefully modify the oil dip stick bracket with a pair of channel locks & bend it into position. I have done two so far. Mine & a buddies about 2 weeks ago when we installed both of ours in 1 day.
04 GT 5 spd, S1, Mopar Sways, Eibach springs, Airbox mod, K&N drop-in filter, AGP & AMX hard pipes, debadged, PTeazer grill, bumperette, rollpan, Cowl Induction hood & other assorted painted parts!!!
vB code is On
stage 1 install problem gooberff Stage Turbo Kits 6 29 Jun 2005 12:22 am
Turbo problem solved hifiman General Turbo Discussions 2 17 Jun 2005 07:27 am
Stage 1 with Dual exhaust Problem go-vair Turbo Performance 5 29 Jan 2004 10:17 pm
Transmission Problem - Stage I mich_132003 Stage Turbo Kits 22 11 Dec 2003 02:00 pm
Stage 1 in, but still have WOT problem. TurboDanny Stage Turbo Kits 15 24 Oct 2003 04:48 pm
  Loans | Credit Report | Mortgages | Personal Finance | Remortgages
