worst than stock
Old 24 Dec 2005, 05:34 pm
Default worst than stock
first i instaled stage 1 better performance after i installed stage 2 wastegate and prototype power kit and the car feel not good lost of power big power and wen shifting lost of power my auto tranny dont feel good i removed all the mod exept for stage one and is better maibe my stage 2 wastegate is not well adjusted??? please help me i see all of you guys with full modification and me trying to ave a better 1/4mille time and its doesnt work and i lost money for noting[xx(][:I]
Old 24 Dec 2005, 08:44 pm
I would think it was how you had your S2 wga adjusted. How much boost did you have it adjusted for? I had it adjusted for 13 #'s of boost. there was a definite boost in power. The Prototype Power system is excellent and that would not be your problem. The stage 1, S2 wga and Prototype system should make your car scream. Mess around with the adjustment on the S2 wga and you should be fine.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 03 Jan 2006, 11:17 pm
Well, first, I have to say that if your mechanical skills are as good as your grammer and spelling when typing, then I'm not entirely shocked that you haven't gotten it to work right. The WGA is one of the best mods you can do to make power, so something to do with the install/set-up of it must have been off. You have to adjust it to about 13psi using a line straight from the back of the turbo to activate it when you are doing the setting. Then you go back and hook up the stock lines or put in a BC.
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
Old 04 Jan 2006, 12:28 am
Hey, TiC, would that be Grammer, Indiana, or were you referring to grammar?
Forgive me, just an old teacher - couldn't help myself...
Note that this Cruiser user's mother tongue is French...
On a more serious note, your recommendations sound sound...[?]
2005 Turbo Lite, Stage 1, Mopar/Borla cat-back exhaust, Eibach swaybars, Bilstein coilovers, 18/8 TSW Montage wheels with 225/40/18 Exclaim UHPs, LED taillights, K & N drop-in & a few other goodies...
Old 05 Jan 2006, 01:10 am
Yes, I should use spell check now and again. French? "Steve Smith" doesn't sound very French to me, but he is in "O' Canada" so you're probably right. I just had to read it over a few times and insert all the "the", "for", "a", etc. to make sense of it. Steve, don't take it personally, I was just giving you a little friendly American bull-stuff!! Anyways, Steve, you didn't spend money for nothing. You just need to have patience and keep working with it and it will all come together.
Mods...
Old 30 Jan 2006, 09:51 pm
tank you very mutch and my wastegate was not adjusted i just put tem on and a was tinking is pre adjusted lol so i removed and adjusted at 4mm and put a ebc greddy profec type2 but i cant try it till srping when the snow gone and yes im a french from quebec im not write very well english but im can read very well[8)]
black 2004 limited edition with turbo lite stage 1 mopar bov and boost gauge. prototype power kit. k&n air filter s2 wga ebc greddy profec type 2 http://turbocruiser.monchar.com/
Old 31 Jan 2006, 04:28 pm
Can you please explain what that means?
2004 Electric Blue GT 5-Speed
Old 27 Feb 2006, 09:45 pm
You tune the wategate by setting it to 13 psi with the bc disconected or turned all the way down. then using a boost controller you fine tune your boost level. This insures that you will not get less than 13 psi but you can move up from there.
2004 Pt Cruiser GT
5-Speed
O&A Party Rock!
www.wackbag.com
Old 01 Mar 2006, 07:15 pm
Well, this is were I'm confused.
The Stage 1 with stock WGA is supposed to peak at 14 psi or so. St 2 WGA is a bolt on mode (asume I don't use a BC). According to ppl who installed this WGA it's supposed to boost crazy fist and then calm down after which you can tune it to the desired level (usually 17-18 to about 15 at redline) by turning the nut on the arm.
So 13 is kind of falling out of this picture. Is it a peak setting or redline? Why woudl you want to have it that low anyway?
Old 05 Mar 2006, 11:51 am
thanks for the info topless in calif !!
F/S Stock Rotors, Rear Seats, Shocks, Struts ptcruzin42 Classifieds: For Sale/Trade 2 11 Mar 2005 08:40 pm
As promissed, Stock PT vs Stock PT with PCM Reset Ian-PT-GT General Turbo Discussions 8 19 Jun 2004 09:57 am
Age old question (again) max tire size stock wheel BobM_CT Wheels, Tires, Suspension 8 21 Nov 2003 02:53 am
Want To Buy - Stock GT Intake and Stock BOV gsharrock Classifieds: Want To Buy 2 16 Aug 2003 12:08 pm
FS: REAL stock 16X7 chrome wheels, stock hood renichms Classifieds: For Sale/Trade 0 15 Feb 2003 03:14 pm
