PT Cruiser Forum Car Videos
Car Rims
Stage 1 question
Old 22 Mar 2006, 10:49 am
rszappa1 rszappa1 is offline
Default Stage 1 question
If you install the stage 1 and then down the road you decide to take it off and install the factory pcm box do you have to have it reflashed or just reinstall the old one and move on...
Old 28 Mar 2006, 09:39 pm
Dream4's Avatar
Dream4 Dream4 is offline
You do not have to do the auto relearn or have anything flashed for the Automatic trans when you switch back and forth, the shift settings are in the PCM, not the trans when you put the S0 back in it will shift normal, and when you put the S1 back in it will have the upgraded shifts and the mileage is not programmed in the PCM, it is put in a data base when you order it so that DC knows when you installed it.
'05 GT Dream Cruiser Series 4. No.1109
http://www.alcamar.com/mods/
http://www.alcamar.com/dc4
http://www.alcamar.com/trailer/
Old 29 Mar 2006, 12:31 pm
Black_GT Black_GT is offline
Yeah, everything from 2003 forward uses the NGC controller, whereas the TCM is integrated into the PCM. That said, since the 41te is an adaptive transmission, it is always learning. Drive real hard for 100 miles and it learns that and shifts accordingly. Drive like Grandma and it learns that, too, and your mileage will go up. That said, anytime you make a change a signifigant change to the power of the engine, you should do a quicklearn. Or, you can just burn up your clutchpacks and join the throng bitching about Chrysler trannies.....
2004 PT GT -Stage 1, K&N Drop-In, Airbox Mods, \'05 Composite Manifold, AMX TTAB, NGK V-Powers at .040, Magnecore KV-85\'s, Mopar BOV, BTG Strut Bar, Mopar Rear Sway, Drilled/Slotted rotors, Hawk HPS Brake Pads, a few visual Mods, a coupla Road Runners, and a Partridge in a Pear tree......
Old 30 Mar 2006, 02:11 pm
PtCruiserDan PtCruiserDan is offline
can you tell me exactly what is stage 1 ...I know it s perfomance stuff...but what does it inplicates..in terme of mod to do ?
thanks.
Old 30 Mar 2006, 03:47 pm
here's a link: http://www.mopar.com/street/products_ptturbo_stage1.htm
That should explain it. It's also the base for evry major power mod, ie, boost controller, upgraded WGA, DTEC, PPQ, 50 trim, etc...
vB code is On
Stage 1 question stranger Stage Turbo Kits 1 01 Sep 2006 07:59 pm
Stage 1 Question? cycletron General Turbo Discussions 4 26 Sep 2005 11:50 am
Stage 1 kit question DREAM2 Stage Turbo Kits 5 17 Apr 2004 10:59 am
Stage 2 Question Mean Green Stage Turbo Kits 10 20 Mar 2004 07:54 pm
Stage 1 time question AA PT Stage Turbo Kits 11 02 Dec 2003 06:20 pm
  Mortgage Calculator | Turbo Tax | Personal Loans | Magazine Subscriptions | Money
