1/4 mi times with stage 1
Old 13 Feb 2007, 02:35 pm
Default 1/4 mi times with stage 1
hey all... how quick are your 5 speed stage 1 PT's moving out in the 1/4?
Old 13 Feb 2007, 07:43 pm
[8)]If you are good, mid to low 14s and mid to high 90s
http://memimage.cardomain.net/member_images/10/web/2098000-2098999/2098527_7_full.jpg
Old 14 Feb 2007, 03:10 am
whats the cheapest way to get these things consistantly into the high 13's?
Old 14 Feb 2007, 05:31 am
Stage 1, AGP wga, dual stage boost controller and slicks.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
Old 14 Feb 2007, 11:06 pm
Has anyone got times before and after Stage 1?
Old 22 Aug 2007, 07:08 pm
Send a message via AIM to blu03gt
Default Re: 1/4 mi times with stage 1
mind if i ask what a "AGP wga" is ? where is the best place to get a dual stage boost controller ?
Old 22 Aug 2007, 07:36 pm
Here's a list of the fastest PT turbos.
http://home.comcast.net/~cuillard/FastestTimesList.htm
One thing I left out before you start raising the boost is a boost gauge. I used an Auto Meter
AUTO METER® MECHANICAL VACUUM BOOST GAUGES - JCWhitney Auto Parts
AGP wga
AGP Turbochargers, Inc. :: SRT-4 :: Boost Control/WGA :: SRT-4 Wastegate Actuator Kit
It says SRT-4, but you'll find a lot of the parts are interchangeable with the PT turbo.
This is the DSBC I used.
AGP Turbochargers, Inc. :: SRT-4 :: Boost Control/WGA :: Turbo XS Dual Stage Boost Controller
Old 22 Aug 2007, 08:03 pm
im amazed at how cheap these parts are, compared to adding more power to an N/A engine. i have a boost gauge, i just need to get an air/fuel gauge and the a-piller gauge pod. so 17psi is max with the stock fuel system ? how much boost does the car make in stock form ?
Old 22 Aug 2007, 09:03 pm
Stock boost is spiking 13 and dropping to 11 at redline. Stage 1 is spiking 15 and dropping to 13 at redline.
Old 22 Aug 2007, 09:23 pm
I had my AGP wga set at 11 psi. First stage of my DSBC was set at 15 psi. No PTB (part throttle boost) and you could drive around all day on the first setting. Second stage of the DSBC was set at 18 psi. PTB was bad in the first two gears. The best way to drive it when you were really getting on it was to use the first stage of the DSBC for the first two gears and when you hit third gear you flip the switch to the second stage of the DSBC. Then you'd better hang on.
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
1/4 MILE TIMES WITH STAGE 1 MARKS-GT Stage Turbo Kits 28 17 Sep 2005 05:46 pm
Stage 0 track times Mr.Blonde General Turbo Discussions 7 28 Nov 2004 09:41 am
Stage 2 1/4 mile times estimates macster Stage Turbo Kits 12 14 Mar 2004 05:52 pm
Stage 2 info from SRT-4 site dtbrks Stage Turbo Kits 24 26 Nov 2003 05:24 pm
  VeraciTek, Inc. - We Build Websites | Internet Advertising | Find jobs | Find jobs | Kamala
