PT Cruiser Forum Car Videos
Car Rims
Latest Stg. I Upgrade Info from MOPAR employee
  #11 (permalink)
Old 03 Jun 2003, 05:24 pm
Kirby Kirby is offline
My question concerns the PCM: is this a new module that can be swaped for the old by the "un-plug/re-plug" technique, or do we have to remove and replace chips?
The Injectors and gaskets are a slam dunk though.
  #12 (permalink)
Old 03 Jun 2003, 05:33 pm
COP TZER COP TZER is offline
sounds sweet, i'm gonna see if availability is any different for Canada...
My Cruiser is slow. I love the law.
  #13 (permalink)
Old 03 Jun 2003, 05:56 pm
Gary04GT Gary04GT is offline
How much do you think the cost might be for dealer installation so everything would be covered under warranty?
  #14 (permalink)
Old 03 Jun 2003, 06:07 pm
earringboy earringboy is offline
...I think the new gasket is for re-installing the upper manifold when it is removed and replaced in order to install the new injectors...
  #15 (permalink)
Old 03 Jun 2003, 06:20 pm
PT-Dave PT-Dave is offline
quote:
originally posted by Dalite:
If the Intake Manifold gasket is thinner than the stock one, then the compression may be raised; making up some potential HP at the same RPM and boost. If it is thicker, than the compression may be dropped further to allow higher boost levels to be obtained (for some reason, yet to be explained).
I have an issue with this statement, Dalite. The gasket between the upper & lower intake manifolds would have no effect on compression that I can see. It would only make the distance for the air charge to travel a minute amount more or less. I have not looked under the hood since reading about all this, but could the reason for the gasket replacement be due to the necessity to remove the upper intake to replace the injectors? I'm just guessing here, since I have never done anything like that. Maybe it's just a stonger, more durable gasket, or, maybe it has some heat insulating properties to enhance performance. Again, just guessing.
PT-Dave
2003 Cranberry Turbo GT
Stage I, custom 3\" exhaust & Cowl Intake, Mopar BOV, Dual gauge pod w/vac-boost & A/F meters, Hood Struts, Yokohama ES-100\'s
Best 1/4 so far: 14.489 @ 93.65, best 1/8: 9.222 @ 74.261
  #16 (permalink)
Old 03 Jun 2003, 08:21 pm
Exhaust Depot Exhaust Depot is offline
Send a message via AIM to Exhaust Depot
I think you guys might get more power out of yours being that your stock boost level is only 5psi where as ours is 11psi. So if they raise your boost up past 11psi as im guessing it will do on the srt, then you will yeild more HP.
E.D. 3\" Turbo Back, , HKS SSBOV, GReddy-e01 Boost controller, Greddy E-manage fuel management, Blitz Turbo Timer, JE pistons, Ported Head, E.D. Large Frontmount Intercooler, E.D. Tubular manifold with t3/t4 (prototype), IPP coilovers, Limited Slip.
  #17 (permalink)
Old 03 Jun 2003, 09:07 pm
Dalite Dalite is offline
I think both of you are correct about the intake gasket. I was thinking old tricks with base gasket thickness, and not thinking it through. I haven't ever had to go into anything that used injectors before, so my lack of experience shows here; loudly.
Is the injector replacement something that the average weekend wrencher would want to undertake? I wonder what the labor tab would be at the dealership. I haven't owned a torque wrench for the past 15+ years.
  #18 (permalink)
Old 03 Jun 2003, 09:19 pm
Kirby,
The PCM should be replaced as a unit, from my understanding. After removing Negative battery cable it would be a matter of clearing a path (clutch slave cylinder and/or other items mounted to the PCM bracket) unplugging 3 or 4 connectors (3 for the Manual trans, 4 for the auto trans), unbolting the PCM bracket, unbolting the PCM from the bracket, mounting the new pcm to the bracket, and mounting the bracket to the firewall. Then replace standard obstacles, reconnect negative cable and back in business.
I think some of the "chip" manufacturers install internal "piggyback" circuit boards that parallel additional processing to the original ROM, EPROM or EEPROM in the PCU, but I don't think that Mopar is counting on this being done at the customer or dealer level.
  #19 (permalink)
Old 03 Jun 2003, 09:45 pm
GTPT GTPT is offline
The only thing that would affect compression ratio would be the thickness of the head gasket.
Phil
  #20 (permalink)
Old 04 Jun 2003, 12:08 am
dsm_mike dsm_mike is offline
"Is the injector replacement something that the average weekend wrencher would want to undertake?"
I havent done it on this car, but it should be pretty straight forward. Relieve fuel pressure, disconnect the injectors from the wiring harness, unbolt the fuel rail from its mounting points, remove injectors, put the new ones in, and put everything back in its place. I dont think there is anything you would need a torque wrench for. Probably wouldnt take more than 20 min. Your mileage may vary.
Of course, the tab at a dealership would be highly overpriced.
vB code is On
Latest Info on Disc Brake Upgrade blue General PT Cruiser Discussions 5 12 May 2005 02:32 am
part numbers Punch General Turbo Discussions 5 13 Jan 2004 11:46 pm
Mopar Press Release - 11/04/03 skylight General Turbo Discussions 15 24 Nov 2003 05:01 am
Mopar Parts Now Available For Dodge SRT4 skylight PT Cruiser News and Rumors 5 10 Sep 2003 10:33 pm
SRT-4 Mopar Performance Parts skylight PT Cruiser News and Rumors 13 23 Jul 2003 07:26 pm
  Mortgage | Cheap Flights | Mortgage | Encyclopaedia | Personal Finance
