This looks like a good item for some enterprising vendor to offer. The more visable, the better. I would, at a minimum, get used to the idea of making sure that the instruction not to flash without notifying owner is written on every work order, every time it goes into the shop. |
Excellent questions; some of the same that I have had. I have no answers.
The Stage I owners will be in the same boat as the 2004 buyers until the dealers get the updated diag gear. Then, the Stage I (and possibly Stage II owners by them) will really have to keep on their toes when they take their cars in for service. In the past, people that I know who had performance computers requested the dealer not apply any flash upgrades. Unfortunately, they had sent their computers off for programming, and if the computer needed to be updated, it was sent back to the programmer. Now that both the stock one and the Stage I are both supplied by Chrysler, there are going to be some real concerns to be addressed, and for each owner to be aware of... |
Back to the original question. Has any stage 1 owner used their boost controller yet? With what results? Thanks
See Kevin's 2003 Elec Blue GT here: http://www.cardomain.com/ride/477590/1 |
I've been out of the loop for quite some time, and am now just trying to catch up. I have my Stage 1 on its way to me, and hope to install next week. I also have a manual boost controller.
Has there been a response to the originally posed question?
Jumpin\' Joe \'04 Porsche 911 GT3 \'01 Audi S8 \'05 Chevy 2500HD TurboDiesel \'05 Suzuki SV650 |
After more searching, I found comments that S1 allows boost to 14-16 psi range without the boost controller (bc), so the bc should not be used. However, this still is a mystery to me since the original stock max boost is 14 psi, but we all know the PCM would not hold it. That's why the bc.
Does the S1 now hold the boost at the higher level? If so, I'd agree to lose the bc.
This has been discussed before. If you do some searches from the past year here and especially on the SRT4 forums you will see that a BC makes a bigger differance on a Turbo Cruiser with no Stage kit.
With the Stage 1 kit installed a boost-control will let you dial in more boost....BUT the computer will pull timing as your boost increases so you will not see any net increase in HP. I have tried this at the drag-strip myself and found it to be true. What will work with Stage 1 is the "spring-trick" (do a search). For $5 in parts it was worth about 2-tenths in the quarter mile for me. The down-side to this trick is the computer will "learn" the new boost-schedule and then will start adjusting your boost back down. To get around that only install your spring at the track then remove it when your done playing for the day. Deen
GT, 5-Spd, K&N filter, Stage I, AGP 3147 Big Turbo, DTEC Fuel Kit, Tial WGA, Greddy Profec EBC, DCR 55mm TB, 05 Plastic Manifold, 180 Deg. Stat, CCA FMIC, AMX hard-pipes, Water-Injection, STS shifter, Needswings 3\" DP w/dump and Borla Cat-back, BG Drop Springs, Eibach Sway Bars, Panther alloys & Eagle F1 Max-Performance Tires. Best run to date...12.93 @113.45MPH. 77 Blown Vette-runs 10\'s @ 136 MPH. |
Hyracer,
Those where exacly my results when I tested it. With the Boost controller, I actually lost engine punch. I would feel the engine rev up, the turbo spool up but I was getting lower ETs and lower MPH at the track. I use the spring mod permanently. I bought the "Spectre" chromed carburator spring set. got it at p#p B@ys for $5.00. Its Stage 1 compatible, but remember to use the thin one. The thick will be stretched too much and can lock up the Wastegate. I posted some picks in another post: http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=7533 It gets realy hot where the spring is. I just reset the computer before going to the track. Ian
| Final manual boost controller installation | Ian-PT-GT | Turbo Performance | 85 | 05 Mar 2010 03:04 am |
| part numbers | Punch | General Turbo Discussions | 8 | 19 Sep 2009 08:44 pm |
| 03' mopar stage 1+ wga & boost controller | acrbill | Classifieds: For Sale/Trade | 3 | 23 Dec 2006 03:56 pm |
| Boost Controller Versus PCM | FRM3 | General Turbo Discussions | 3 | 08 Oct 2003 10:59 pm |
| SRT-4 Mopar Performance Parts | skylight | PT Cruiser News and Rumors | 13 | 23 Jul 2003 07:26 pm |
