serious noob question
Old 26 Jun 2007, 06:09 pm
Default serious noob question
how are those JET stage 2 chips? anyone ever use them? I would like to know how they are.........Or are they a waste of money and jus better off using a stage 1?
Old 26 Jun 2007, 09:11 pm
CFS CFS is offline
Send a message via AIM to CFS
Default Re: serious noob question
hey how it is going?
take a look at my tread post replies titled : "recommended coustomizations for '03 GT cruiser"
CFS
-2003 PT cruiser GT TURBO Electric Blue
-LoAdEd!!!!
----------------------Current-ADD-ON's---------------
-Air Raid CAI Quick Fit Series 300138: cool:
-Mopar Blow-Off Valve
-MOPAR boost guage
--------------------FUTURE-ADD-ON's-----------------
-MOPAR stage 1 Upgrade
-Propod three guage pod
Old 27 Jun 2007, 10:33 am
apexanimal's Avatar
Send a message via AIM to apexanimal
don't do it
get MOPAR stage 1
forgitaboutit...
'03 GT 5spd: Stage 1+
http://www.cardomain.com/ride/2272425
http://www.ptboutique.com
Old 27 Jun 2007, 07:01 pm
Worthless waste of money compared to S1, to much good stuff to spend money on to waste it on that.
Old 28 Jun 2007, 06:58 pm
another thing, how the heck do people run larger injectors and setups on a stage 1 ? example: t3/t4,38mm wastegate,750cc injectors,etc,...... isnt the stage 1 set up for 527cc injectors?
Old 29 Jun 2007, 06:27 pm
Dream4's Avatar
Actually,the Mopar Stage 1 is set up for 577cc/min injectors, 527 was the stock '03 turbo injectors, the '03 Stage 1 kit came with the 577s, and '04 and up Turbos have the 577s from the factory stock, the bigger turbos and injectors require a piggy back fuel computer of some type, and a high pressure fuel pump, the Stage 1 PCM is just a building block for further mods.
'05 GT Dream Cruiser Series 4. No.1109
http://www.alcamar.com/mods/
http://www.alcamar.com/dc4
http://www.alcamar.com/trailer/
Old 30 Jun 2007, 02:13 pm
so if I wanted to run a bigger turbo with a bigger fuel system, then I shouldnt waste my money on the stage 1 right? I was originally thinking of running a stock computer with either a TURBO XS DTEC or Apexi AFC with the bigger injectors and turbo setup,cause I intend on having a daily driver and I know the hassles of having a dailydriver with turbo lag,bad gas milage.....etc.So is my first idea possible?
Old 30 Jun 2007, 02:27 pm
Dream4's Avatar
One of the reasons for the Stage 1 PCM is that it ignors a lot of signals that will cause a Check Engine Light and set a trouble code, (like over boost codes past 15psi, injectors to rich and other things), All the guys I know running big turbos are still using the Mopar Stage 1, along with a piggy back computer, except one guy that is using the AEM stand alone SRT4 PCM in his Highly modified PT.
Old 02 Jul 2007, 08:22 am
Thanks for the info, and one more question: Ive heard from one of the guys here theres someone who knows how to strenghten up the auto-stick for higher than stock HP. I think he's from PT-CREW. Are there any links to old forums on this site discussing this? Or maybe an company out there who does this?
Old 02 Jul 2007, 10:53 am
Dream4's Avatar
Yes ,there was a trans called the "Power Demon" but they went out of business,(and it turned out not to be strong enough for the big turbo guys), But now there is great transmission guy called "AJ" who goes by the screen name tranman on the above site that you mentioned. here is a link to some info, but if it does nor work just do a search on the Crew site for tranman or Autostick, and you will find a lot of info on the Autostick and it possible improvements, by the way, that will be my next big mod, probably after the first of the year.
PTCrew.com - Learn it or Burn it.
question about head unit upgrade Avus Sound and Security Forum 1 08 Jun 2004 06:32 pm
Question...180/215/220hps enter sakigt General Turbo Discussions 23 04 Mar 2004 11:22 pm
Question for Stage 1/Autostick Folks divots Stage Turbo Kits 1 31 Jan 2004 12:56 am
BOV Question azptcruiser Turbo Performance 15 24 Dec 2003 12:55 am
Newbie with a warranty question! John_Milner General PT Cruiser Discussions 6 25 Aug 2003 07:48 pm
