STAGE 1 INSTALLED AND HAPPY
  #21 (permalink)
Old 30 Jun 2003, 12:58 pm
So with this upgrade running with the manual boost controler at 14 psi would be kinda piontless? If what your saying is that it gets 16.5 psi then drops to 10.
03 GT Patriot
H&R coilovers,CAI,Mopar/Borla exhaust,Mopar stage 1,VAK UCP, Maxxfab 3\" DP,blitz spec r ebc,PSI-FI solid motormounts,AFX udp,turbochargers wga ,18\" g racing seiki w/ blue spokes wrapped in 235/40/18 bfgoodridge Gforce kdw\'s, PTeazer roll pan,hot rod front bumper with custom molded piaa fog lamps,Pioneer 7300 dvd player,1 10\" kicker L7 sub,
  #22 (permalink)
Old 30 Jun 2003, 01:58 pm
My plan of action is to remove the boost controller, install "Stage one" and study the turbo changes. then adjust the controller.
Ian
  #23 (permalink)
Old 30 Jun 2003, 02:34 pm
quote:Originally posted by DTs_PTGT
quote:Originally posted by COP TZER
what do you really mean by the noise on deceleration. I already have straight pipes, will it be a hell of a lot louder??
This is one of the "features" of Stage I, and probably the feature that would be most likely to keep it from being smog certified. The new PCM goes rich on deceleration which allows unburnt gas to get as far as the cat. which causes it to detonate in the exhaust pipe causing a harsher "burble" then stock.
Hope this makes sense.
Do you know about Catalytic converter temps? Will this burn out your cat sooner?
I am not an expert on how this would effect long term function of the cat(the converter is quite expensive due to the proprietary flex coupling at the turbo - there's only one place to get a replacement).
  #24 (permalink)
Old 30 Jun 2003, 02:42 pm
Kirby,
I haven't actually looked at the flexs couple on my PT but there are flex couplings available in the aftermarket. Is there something different about ours?
  #25 (permalink)
Old 30 Jun 2003, 02:54 pm
I'm sure that the aftermarket will make something soon, but I was told that since the converter hooks directly to the manifold(not down the line like others) they had to put a proprietary flex end to deal with engine movement. I don't know that this might be a warranty item for stock PTs with bending the end along with high temps. I certainly don't know.
I would be suprised to see anyone make a "cheap" unit though since the Federal Government makes ALL cat manifacturers warrant for 70,000 miles and this unit will only be for our autos (specialty item).
  #26 (permalink)
Old 30 Jun 2003, 04:56 pm
UniqueT did say the autostick would see more of an increase than the 5 speed. Hope they made the shifts a little more firm.[8)]
  #27 (permalink)
Old 30 Jun 2003, 05:51 pm
I find that if I go into Autostick mode, the shifts are "harder" and happen right at redline (if I let the computer do the shifts) compared to either manually shifting or putting it in "D" and flooring it.
Can anyone else confirm this?
2003 PT Turbo Deep Cranberry \'R\' Package Stock + AutoStick
Came off assembly line 1/14/03 (Tuesday) between 2200 and 2300.
  #28 (permalink)
Old 30 Jun 2003, 06:57 pm
If you keep it to the floor or close to that, the shifts will occur around 6,000 RPM. Just put it in first and stand on it. The shift is firmer because the PCM can't take the time for a "soft" shift between 6K and the rev limiter.
This was even programmed into the old auto trans in the earlier models.
  #29 (permalink)
Old 30 Jun 2003, 07:02 pm
( Oooooh. I want
BigDog! Lemmie know if you get it and install it. I wanna watch )
Saki
I was going to say the same to you. Your alittle bit braver than I am when it comes to working on the Cruiser
  #30 (permalink)
Old 02 Jul 2003, 12:56 pm
Send a message via AIM to sakigt
Ok..Lemmie get this straight.
Stage 1 upgrades computer so you can run at 16.5 PSI w/o error codes?
So with my MBC, running 15 psi, getting codes...my engine is actually ok? Its my computer? [:I]
14.67 @ 94.5 <--- Self Proclaimed Fastest East Coast PT with Black wheels!!!
STAGE 1 may mean better fuel economy! Gary04GT Stage Turbo Kits 10 20 Jul 2004 01:30 am
Stage 1 - Johnny come lately JohnM Stage Turbo Kits 2 28 Jun 2004 05:58 pm
Stage I Installed Mean Green Stage Turbo Kits 8 02 Sep 2003 07:26 pm
Stage 1 Installed today.........My Impressions Gear_Head Stage Turbo Kits 19 19 Aug 2003 10:12 pm
Stage 1 Installed!!! And oh so happy!! ptcruzin42 Stage Turbo Kits 34 18 Aug 2003 06:24 pm
