STAGE 1 INSTALLED AND HAPPY
  #31 (permalink)
Old 02 Jul 2003, 01:51 pm
quote:Originally posted by sakigt
Ok..Lemmie get this straight.
Stage 1 upgrades computer so you can run at 16.5 PSI w/o error codes?
So with my MBC, running 15 psi, getting codes...my engine is actually ok? Its my computer? [:I]
Most likely you're getting codes because the MBC causes high levels of boost at partial throttle. If you use an EBC, you can program it to reduce boost during partial throttle (connect to TPS reading) which will eliminate the error code.
2003 PT Turbo Deep Cranberry \'R\' Package Stock + AutoStick
Came off assembly line 1/14/03 (Tuesday) between 2200 and 2300.
  #32 (permalink)
Old 02 Jul 2003, 03:12 pm
So, what does it do to the Rev Limit? Is it still at 6000 or did they move it up a bit? Damn that comes so fast in first and second gear.
Mike
  #33 (permalink)
Old 03 Jul 2003, 04:37 pm
Setting aside the warranty issues, what sort of changes in drivability do you see?
The power curve seems to indicate that the power band is at least a wide and smoother, does this seem to be true?
In stock mode, premium fuel helps, presumably because the detonation detector limits boost. Does the Stage 1 Require Premium?
Does fuel mileage suffer?
  #34 (permalink)
Old 03 Jul 2003, 07:21 pm
I have been told that the fuel air portion has not been altered, so it should smog out just like stock. AND since deceleration is NOT part of the DEQ cycle,(Idle, low RPM under load, Medium RPM under load)the New kit should pass sniffer with flying colors!
Since your fuel air ratio is the same, the only thing that will change mileage is that heavy right foot of yours!
  #35 (permalink)
Old 04 Jul 2003, 08:06 am
Because we know that nothing comes without a price, what are the trade-offs with this kit?
Or do the horse power gains come from "greater efficiency"?
  #36 (permalink)
Old 04 Jul 2003, 10:37 am
On the question some had concerning cat damage. There are maybe three ways of cat destruction; over rich fuel condition( vapors build up and temperature of cat causes detonation of fuel), anti-freeze or oil deposits, or hitting something in roadway to cause damage to ceramic bricks in cat. Hope this helps.
Phil
  #37 (permalink)
Old 04 Jul 2003, 02:11 pm
Under normal driving can you tell the stage 1 is there, I mean does the car feel stronger, or do you have to put your foot in it to notice?
03 Steel Blue Pearl Turbo, Stage 1, Mopar BOV, Magnaflow performance muffler, My Air Box mod., AMXpipe W/K&N filter, LED lighting,PT Tunning rear lowering springs & BGT Strut tower brace, Hankooks Ventus tires, Rage Motif 17 in. wheels. Tribal pinstrips by Palmer (who else), Color match paint by Etouchup.com, Plugs and wires by Sparkplugs.com, http://members.cardomain.com/rodrungtpt
  #38 (permalink)
Old 04 Jul 2003, 05:17 pm
So tell me what the purpose is then of changing the injectors when the fuel mapping has remained the same??? Also in that case it's basically performing the same function as a boost controller and will also run just as lean???
My Cruiser is slow. I love the law.
  #39 (permalink)
Old 06 Jul 2003, 09:55 am
The service manager at the local Chrysler dealer says the Stage 1 mod will not void the warranty.
However, no car is warrantied against "abuse"
  #40 (permalink)
Old 06 Jul 2003, 03:37 pm
COP TZER, the computer is still trying to achieve the optimal AF ratio. It is just with bigger injectors it will be capable of delivering more fuel in high demand situations where the stock injectors would lean out and cause the computer to back down the timing or boost to stay within safe parameters. There is no point in supplying more fuel in other situations. Running too rich does not increase performance. It is a delicate balance of air and fuel in the right proportions that result in the greatest return.
STAGE 1 may mean better fuel economy! Gary04GT Stage Turbo Kits 10 20 Jul 2004 01:30 am
Stage 1 - Johnny come lately JohnM Stage Turbo Kits 2 28 Jun 2004 05:58 pm
Stage I Installed Mean Green Stage Turbo Kits 8 02 Sep 2003 07:26 pm
Stage 1 Installed today.........My Impressions Gear_Head Stage Turbo Kits 19 19 Aug 2003 10:12 pm
Stage 1 Installed!!! And oh so happy!! ptcruzin42 Stage Turbo Kits 34 18 Aug 2003 06:24 pm
