I am planing on getting a free flow exhaust, down pipe, up pipe and a k&n cone filter intake. Along with new plugs, whires, WGA, trottle body spacer, BOV conversion kit and intake manifold heat sheild. But what about fuel injectors? The stage 1 only has them for the 2003 model! I was just going to get them sepretly with the stage 1 then I saw a stage 2 for the SRT that came with injectors so I though I would try and do that, I guess I should just go with my original plans. And dont tell me that the stock injectors are more than I need because I need more power!!! Arr arr arr I was planing on getting my injectors at RC something like... Flow Rate - LB's: 35 LBS / HR @ 43.5 PSI I was looking at the peak & hold but I am not sure which whould be better, the peak and hold or the saturated.
www.clarklambert.com www.bandcelectronics.net www.knifesword.net www.pcvideogamextras.com |
I was only going by the Mopar Performance Printed Material in 3 years worth of catalogs, and had not heard other wise even over on the Crew where most of the tech info is reliable, you would think that if it really made more they would publish it to sell more product if they were bigger and better.![]() I know the trans are weak, that is why it is next on my mod list, but my point was that the '05 and up Stage 1 kits provide higher numbers than the older Stage kits kits did, I have seen the dyno numbers from both and there is a 30 to 40 hp difference with simmilar mods between the '03,'04s and the '05 & up. But anyway thanks for your input, it is always good to hear documented info, I aways thought they under rated the HP on the SRT4s anyway for the younger drivers insurance. But after I upgrade to a "AJ" trans with my tax refund I already have Stage 2 injectors and Stage 2 WGA waiting for install with some type of fuel management.(hopefully a SCT unit) I am hoping to reach 300whp 300ft-lbs (I already have that torque as long as it does not go down)with out upgrading to a bigger turbo, but If I have to then I will go with one of the stock fitting "Turbofold" types.Do you have a link or webpage with your mods or would you have to kill me if you told me. ![]() Thanks again for the corrected info. Butch PS. For those that want to see I had posted my dyno sheet over on PTCrew and you can see my mods in the link in my sig. PTCrew.com - Learn it or Burn it.
'05 GT Dream Cruiser Series 4. No.1109 http://www.alcamar.com/mods/ http://www.alcamar.com/dc4 http://www.alcamar.com/trailer/ |
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
As others have stated,,, the 41TE in stock form won't take the HP. Heck,,, stage 1 puts it at serious risk. Beyond that,, the pin is pulled. I have trashed a few,, including two so called high performance from Power Demon. A friend of mine has a ton of auto experience,, has done a lot of R&D with my car,, and has made great leaps in getting the 41TE to survive higher HP levels. The weakest point seems to be the OD section. Stock it as 4 clutches,, a lot of folks have put 5 in,,, mine and a couple of others now sport 6 in the OD. BUT still the warning is do not boost in OD. AJ has done other major changes to the 41TE.
SO no S2, but there have been some interesting developments last year,,, A company called SCT has released a flash tuner for Mopar. I am currently testing one in my PT. It has the capability to go far beyond S2 programming. Tom |
What can those of us with a manual transmission expect? can we safley add stage 1 with a few other after market bolt ons or is that pushing it for our stock transmission?
With the five speed you'll be fine.
If you really want to mod things out the Eclipse 6 speed Tranny was designed for a car running 330hp. my mechanic buddy checked the block pattern it will block directly on.
Also check out Youtube there is a video of PT on a dyno running 599hp 649 lbs torque. Anything is possible if you have the bucks
Boring Gold PT, oops that was 4 years ago
| Are there any step by step instructions for mopar stage 2 wastegate and or dual stage | dmkolb | Turbo Performance | 7 | 04 Aug 2010 03:44 pm |
| Stage II for PT is here! | skripo | General Turbo Discussions | 9 | 12 May 2008 09:11 pm |
| Stage 1 and 2 modules on Ebay | pdbrains | Stage Turbo Kits | 3 | 16 Aug 2007 12:06 pm |
| Tour de Lance STAGE 7 | PTRON | Non-PT Discussions | 0 | 10 Jul 2004 07:13 pm |
| Stage 2 info from SRT-4 site | dtbrks | Stage Turbo Kits | 24 | 26 Nov 2003 05:24 pm |
