With an 03 (injector upgrade) absolutely do them both at once and since the intake will be off consider a DC oil modifier which is a nice little mod for only $20.00.
absolutely. it gets rid of the lean condition in cylinder 1. less weight, iess heat soak, and 8hp bump with the intake. stage 1 is a good upgrade. nice hp jump and smoother transmission shifts. and remember if ya go stage 1 you'll need a boost guage.
"Every civilization finds it necessary to negotiate comprimises with it's own Values" |
Actually, you'll need a boost gauge if you go beyond stage 1 numbers by getting an adjustable wga or boost controller.
\'05 Stone White SRT4 \'04 Graphite PT Automatic |
I have a boost gauge, it was fitted when I got the car, not sure why I need one though?
There is not that much set up required with stage 1 is there? (my car's a manual too)
To be old and wise, you must first be young and stupid.
You get larger injectors and a new pcm. You don't need to do a tranny learn.
Depending on your skill level this may sound like a lot. It isn't really but if you are afraid of the task there is probably someone on one of the board that lives near you that would help you out. It is a little more involved if you are doing the manifold at the same time but it would be the time to do it since you are in there anyhow. Change your plugs and wires while you are at it. Plugs will be harder once you have the composite manifold on.
| PLASTIC GT MANIFOLD PROBLEMS? | littleblueGT | Turbo Performance | 45 | 25 Nov 2011 12:10 pm |
| Plastic Intake Manifold cracked-boost leak! | littleblueGT | General Turbo Discussions | 1 | 31 May 2007 03:25 pm |
| Turbo plastic manifold on N/A PT? | littleblueGT | Tech & Performance Forum | 4 | 24 Jan 2007 01:05 pm |
| Plastic Manifold in Summer? | littleblueGT | General Turbo Discussions | 4 | 22 Jun 2006 10:10 pm |
| Plastic manifold & plugs | quicksilverdon | General Turbo Discussions | 3 | 21 Mar 2006 12:48 pm |
