stage 1 computer question
  #11 (permalink)
Old 25 Aug 2008, 03:07 pm
loxmith's Avatar
Default Re: stage 1 computer question
Interesting...stage 1 increases the MPG, I'd have thought it would be the other way around.
  #12 (permalink)
Old 25 Aug 2008, 03:18 pm
nevinsrt's Avatar
if your nice and put around you'll see alittle better gas milage.
Nevin.
03 SRT-4 — 132k mi ported stocker and lots of other stuff
68 Mustang Coupe — project fail!!
PT Less - ex wife took in the divorce 3/2011
05 GT Cruiser H.O. — last dyno 245hp/283tq @ 15psi — OCT 08
3 in intake, Stage 1 PCM, Stage 2 WGA, ported turbo@21psi, 682cc, 160 deg T-stat, Check valve, Ngk 4306 plugs, 10mm spark plug wires, 3in O2, 3in DP, 3in Y-pipe with E-cutout, 2.5 in catback exhaust, upper/lower hardpipes, HKS SSQ bov, block off plate, Energy Suspention MM inserts, NSRT hawk HPS front/rear pads, NSRT Drilled/slotted rotors, NSRT steel braded front lines, Mopar 26mm Swaybar, NSRT energy suspention swaybar bushing, NSRT energy suspention swaybar endlinks, APC Non-turbo strut bar, Black housing headlights, Tinted rear tail lights, Schroth 4 point harness, Perrin catchcan, 3 pod a-piller, boost guage 30/30, oil pressure gauge, volt gauge
  #13 (permalink)
Old 25 Aug 2008, 03:23 pm
It's all in having more torque.
\'05 Stone White SRT4
\'04 Graphite PT Automatic
  #14 (permalink)
Old 07 Sep 2008, 11:38 pm
Dirk_Gently's Avatar
Let's not forget the best part of s1 pcm - 3 words No Lift Shift!
Oh, and it'll keep your trouble codes to a minimum.
Wait wait wait, if "boost gets your laid" how come all you get is shaft play?
Idling Question about Stage 1 ??? retroman715 Stage Turbo Kits 8 26 Aug 2004 12:04 pm
HELP Stage one question scottscars Stage Turbo Kits 4 11 Aug 2004 08:29 am
Stage 1 kit question DREAM2 Stage Turbo Kits 5 17 Apr 2004 10:59 am
Stage 2 Question Mean Green Stage Turbo Kits 10 20 Mar 2004 07:54 pm
New Here - With a Computer Question... Martin Logan Tech & Performance Forum 1 12 Nov 2002 12:12 pm
