Stage I Instructions
Old 05 Aug 2003, 09:47 pm
Default Stage I Instructions
56Kb beware! This link contains over 1MB of jpg files. You've been warned.
Here are the Stage I install instructions. The quality isn't the greatest as these scans were taken from a photocopy of the originals, but are clear enough to read.
http://home.comcast.net/~dtibs/mprs1/index.html
Old 05 Aug 2003, 10:03 pm
Your images are better than the actual instructions I got with my kit...
Ian
Old 06 Aug 2003, 09:29 am
ptgtcb,
Pages 7 & 8 are there (just double checked), you may just need to wait for everything to load.
2003 PT Turbo Deep Cranberry \'R\' Package Stock + AutoStick
Came off assembly line 1/14/03 (Tuesday) between 2200 and 2300.
Old 06 Aug 2003, 12:37 pm
I can't begin to thank you enough. This was a monumental help!!
Old 06 Aug 2003, 12:44 pm
no problemo, Kirby mon! I just hope everyone can deal with my super-rudimentary HTML skillz!
If there's any interest, I can post BOV install instructions as I received mine last night (thanks again, tthrift).
Old 06 Aug 2003, 02:21 pm
Please do. thanks
culprat@sbcglobal.net
Old 06 Aug 2003, 07:40 pm
The instructions have a few errors.
It looks that the instructions where made with a bare engine or there is a bad QC when the cars where built. Here is my Addendum:
Remove the air filter housing and the turbo intake pipe.
It says to remove the three screw holding the PCM bracket, there are actualy Four.
It also tells you after you have installed everything, to clean the manifold gasket residue. This should be right after the top intake manifold removal and covering the intake ports.
In the removal of the thermostat/filler port, there is a bracket installed to one of the screws, It also has a 1/4" screw on the side of the thermostat housing that holds this bracket. It needs to be removed for the thermostat cover to move.
The BOV install is kind of screwy also.
Ian
Old 06 Aug 2003, 10:39 pm
I found with the BOV install, it helped a little to undo the oil line going into the top of the turbo housing and move it aside. I think it was mentioned on here before(PVO PT) a 10mm wratchet wrench looks like it would help. I didn't have one and a smaller set of hands[?]
Old 06 Aug 2003, 10:48 pm
I haven't taken part in a Stage I install, I just passed on the instructions because I had the chance.
Old 06 Aug 2003, 11:06 pm
DTs PTGT,
Please post the BOV instructions!
Thanks,
Scott
\"If you choose not to decide, you still have made a choice.\"
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
"Stage Turbo Forums" Killed by Mopar hyracer Stage Turbo Kits 20 28 Apr 2005 04:26 pm
Tour de Lance STAGE 7 PTRON Non-PT Discussions 0 10 Jul 2004 07:13 pm
Stage 2 info from SRT-4 site dtbrks Stage Turbo Kits 24 26 Nov 2003 05:24 pm
Stage One install instructions skylight Stage Turbo Kits 2 30 Jul 2003 02:17 am
