Boost
  #11 (permalink)
Old 04 Sep 2003, 09:56 am
I too get 15 psi, sometimes 16 psi at WOT on my 5-speed GT.
2003 Electric Blue PT Cruiser GT 5-spd
MOPAR Stage 1 kit
Custom Stage 1 emblem on rear hatch
Greddy Turbo Timer
AGP factory surge valve blockoff plate
AGP/TurboXS Type H-RFL BOV
160 degree thermostat
Magnacore plug wires
Champion RE14PLP5 Double Platinum plugs gapped .050\"
Screamin Demon coil
Momo shift knob
3 gauge pillar pod with Autometer Lunar boost, EGT and oil pressure gauges
Stewart Warner Shift Light
Streamline Designs third brake light overlay \"Turbo Cruzer\"
Rear splash guards
Rear spoiler
Hidden Hitch
Ichiban pedals
Streetglow Xenon headlight and foglight bulbs
PCV line oil seperator
Firestone Firehawk SZ50 215/50R17 tires
PT Tuning axle back exhaust and muffler
Mr. Dyno vehicle performance computer
Pioneer DEH-P77DH AM/FM/CD
Kenwood KSC-WA62RC — The WooX 30w x 2 powered subwoofer
  #12 (permalink)
Old 14 Sep 2003, 02:01 pm
got my S1 installed, checked all the lines and stuff. At 2nd gear WOT i pull maybe 13 pounds of boost. For some odd reason I can't tell if it is running stronger thru the gears.
the exhaust has a nice tone with some burbles and pops. But 1st gear I do't drop, so i haven't tried anything with that. What should I expect from the 5 spd?
Only changes are a 2.5" exhaust from the cat back and aftermarket 17x8" wheels.
No leaks in coolant system and the car otherwise runs fine.
The boost gauge is electric. it has it's own MAP sensor between the gauge and the tap in the vaccuum line. Pre-S1 boost levels were 10-11.
Homepage:
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
AGP wastegate w/o boost control strangelove Turbo Performance 13 13 Mar 2007 01:22 pm
Boost Question Mel K Turbo Performance 2 04 Apr 2004 09:27 pm
Taking control of the boost Jason_L Turbo Performance 2 03 Jan 2004 10:35 pm
20lbs of boost and no eng lite amx1397 Turbo Performance 6 21 Jun 2003 07:20 pm
