Boost
Old 10 Aug 2003, 10:06 pm
Default Boost
After I installed the stage 1 kit, Did the tranny learn thing, All works great but I did notice now that my boost will only go to 10 psi. It stays at 10 through all throttle but I used to get 14. Any clues I should look at?......Thanks......Andy
Old 10 Aug 2003, 10:40 pm
Just curious, is your speedometer working???
Old 11 Aug 2003, 08:14 am
There is defenately something wrong.
I get 15 PSI and sometimes 16 and it is also an auto stick.
Ian
Old 11 Aug 2003, 09:15 am
yes my speedometer is working.
2003 Inferno Red GT with a few chrome goodies.
Old 15 Aug 2003, 12:18 am
Any suggestions?
Old 15 Aug 2003, 12:58 am
At58,
Does the car seem to be running better? I mean, does the Stage 1 kit seem to be doing the job? If yes, then it would appear that there may be a problem with your boost gauge, boost tap, or line to the gauge from the tap. If no, then I would check to make sure that all of your vacuum lines and hoses are ok (tight, no holes, etc..) and check your boost tap and line again. From what I have read and understand, you should be generating a lot more boost, particularly in first gear. When the Stage 1 kit was installed, a lot of hoses were disconnected. Check to make sure everything is intact and connected properly. Let us know what happens.
My two cents,
Scott
\"If you choose not to decide, you still have made a choice.\"
Old 15 Aug 2003, 01:25 pm
Thanks for the info Scott. I'm gonna tear it apart again this weekend.
Old 03 Sep 2003, 09:53 pm
I boost at WOT stock with my 5-spd at about 10-11psi.
What am i looking at with the Stage1?
Homepage:
Old 03 Sep 2003, 10:10 pm
Send a message via AIM to tthrift
please check everything once again , i boost too 15 psi and sometimes 16 psi. if you can't find anything wrong please email or call me and i will put you in contact with the right people that can help you.
thanks tommy
Old 03 Sep 2003, 10:20 pm
DC2 DC2 is offline
Just put my stage 1 in today and get 16 psi boost and it holds at that psi good car runs outstanding did you instal bov? mine is on BO
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
AGP wastegate w/o boost control strangelove Turbo Performance 13 13 Mar 2007 01:22 pm
Boost Question Mel K Turbo Performance 2 04 Apr 2004 09:27 pm
Taking control of the boost Jason_L Turbo Performance 2 03 Jan 2004 10:35 pm
20lbs of boost and no eng lite amx1397 Turbo Performance 6 21 Jun 2003 07:20 pm
  Debt Consolidation | Advertising | Wordpress Theme | Kim Kardashian | Song Lyrics A to Z
