PT Cruiser Forum Car Videos
Custom Wheels
Coolant drain
Old 15 Aug 2003, 12:19 am
Chz Chz is offline
Default Coolant drain
I tried to drain the coolant as part of the installation of Stage1 injectors. I was able to turn the valve 90° but no more and no coolant would drain. Should the valve turn more than 90° or is my drain valve defective? I got around the problem by pulling coolant out of the top tank and catching a few drops that leaked at the thermostat housing but I want to know if I can get the coolant drained in the future or do I need a new valve?
Old 15 Aug 2003, 12:47 am
ElectricBlueGT ElectricBlueGT is offline
Chz,
When you turned the valve, was the coolant system cap off? [It looks like a radiator cap] If not, little, if any, coolant will drain.
Scott
\"If you choose not to decide, you still have made a choice.\"
Old 18 Aug 2003, 10:44 am
Chz Chz is offline
Several others are also reporting that the drain valve doesn't open. Any ideas? It's not necessary to vent the cooling system because it will pull coolant out of the over-flow bottle.
Old 18 Aug 2003, 05:07 pm
Cal Cruzer Cal Cruzer is offline
I just did it over the weekend when we installed a Stage 1 upgrade on R_K_GT's car and it only turns a little. And it will come out if the cap is off
Old 18 Aug 2003, 06:09 pm
Gear_Head Gear_Head is offline
I did my stage 1 this weekend, and turned the drain valve 90 degrees (Max Limit) removed the system cap (radiator cap) and did all that I knew how to do to the damned thing & there was no way that even a drop of fluid came out. Fortunately the cruiser was up on the lift, so I removed the lower radiator hose to drain the system. Drained it all, & installed fresh coolant. [:I]
Alan
Old 18 Aug 2003, 11:37 pm
Chz Chz is offline
I was told to turn the valve 90° and "pull it out". This is a Mercedes design. It works.
Old 19 Aug 2003, 02:58 pm
We only had to drain about a quart to do the upgrade.
vB code is On
lost coolant onyx pt Turbo Performance 10 27 Mar 2007 11:50 pm
Oil drain plug AlmondTurbo General PT Cruiser Discussions 2 07 Feb 2007 04:54 pm
Check & drain you water heaters, A/C , &.... Espresso Non-PT Discussions 17 12 Jul 2005 11:47 am
Drain plug DREAM2 General Turbo Discussions 11 06 Jul 2004 10:14 am
Leaking coolant line TripleJackInGA General Turbo Discussions 0 03 Oct 2003 10:00 pm
  Mbna | Payday Loan | Online Advertising | Internet Advertising | Gas Electricity
