Dyno #'s prior to Stage 1 install...
  #11 (permalink)
Old 18 Aug 2003, 12:08 am
Mustangs used a 'rule of thumb' of 15% loss for a manual and 20-22% for an auto. I would assume that the numbers would be similar for other cars
  #12 (permalink)
Old 18 Aug 2003, 02:12 am
From what I've read, most 5spd. have been dynoing at 200-210 at the wheels. Quite a difference from the Auto's.
\'03 Inferno Red 5 spd. Hurst shifter,Loaded
  #13 (permalink)
Old 18 Aug 2003, 10:45 am
One thing you should consider also is the number of miles on the vehicle.Yes, an Automatic will have more parasitic loss through the drivetrain, but my past experience with Dakota R/Ts showed that the engine actually was noticeably improved with approximately 30k miles or so on it.
I would be curious to see your first run with the silencers in and a paper filter (basically stock), then run #2 with just the silencers removed, then #3 with the K & N added, just to get an idea of what each mod adds.
Also, you need to look at the relative humidity, ambient temp., and elevation when you did these runs.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
  #14 (permalink)
Old 18 Aug 2003, 01:34 pm
Too late TripleJack, Stage 1 and BOV are in now. My uneducated guess is that ther is a whole lot more torque and power now. Robert also mentioned that there are a lot of "holes" in the powerband with the stock setup.
  #15 (permalink)
Old 18 Aug 2003, 08:30 pm
those stock numbers seem really low, i wonder what happened?? I need to get to a dyno soon too.
My Cruiser is slow. I love the law.
  #16 (permalink)
Old 18 Aug 2003, 08:44 pm
I also mentioned to Robert that there are some beneficial ponies laying around also. Differential box... switch to synthetic (hands down, Red Line is the best). Automatic Transmission fluid, switch to synthetic (Mobil 1 is good). Engine oil(Mobil 1 5-30 works great).
Best guess is about 5 hp, better engine/trans life, and better gas mileage!
Robert doesn't even have 2k on the odo yet (it's still a baby).
  #17 (permalink)
Old 18 Aug 2003, 08:51 pm
Again (from most of what I've read and seen posted), the auto's aleays seem to be around the 175-190hp. with the Sticks higher... usually in the 200-210 range. due to as Cal put it "parasitic loss".
Install price for stage 1....crazy. Mr.Barton Stage Turbo Kits 14 17 Dec 2005 07:30 pm
stage 1 install problem gooberff Stage Turbo Kits 6 29 Jun 2005 12:22 am
Dyno: Stage 1 5-Speed Manual PTGT_Boy Turbo Performance 0 24 Oct 2004 03:45 pm
Dealer Refuses to Install Stage I Adman Stage Turbo Kits 7 13 Sep 2003 04:41 am
Macster's Stage 1 Install macster Stage Turbo Kits 9 23 Aug 2003 11:46 pm
