remove the cat. with stage 1 kit
Old 16 Aug 2003, 05:32 pm
Send a message via AIM to tthrift
Default remove the cat. with stage 1 kit
has anyone removed the cat. converter that has the stage 1 kit installed. some where i heard if we have the stg 1 kit and remove the cat. the engine light won't come on.
does anyone know the answer?
thanks tommy
Old 17 Aug 2003, 07:48 pm
I wouldn't want to get caught doing that, that could really make feds
Tom
Old 17 Aug 2003, 08:38 pm
My solution for that was an exhaust dump that I made installed before the cat. Basically it is a Y pipe, one route goes throught the standard exhaust (feds would be happy) and the other, when uncapped, would vent directly to the atmosphere (for race purposes only []). I've got pictures of the setup on my other car if anyone is interested. The results were that the boost spooled up MUCH quicker and gained quite a bit of top end power. It wasn't really all that loud because the turbo acts as a muffler.
Marc
2003 PT Cruiser GT Turbo, Silver
1985 Dodge Omni GLH Turbo 16V, Black
http://connect.to/YBT
Old 18 Aug 2003, 10:49 am
Isn't there an 02 sensor in the cat though? I would think it would trip an MIL, but who knows. Either way, you can hook a resistor to the O2 plug end to make it think all is well......at least we did that on the Dakotas.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
Old 18 Aug 2003, 11:24 am
My understanding of the system is there are (2) O2 sensors, one in the cat and one upstream of the cat and the PCM looks at both inputs to insure that the cat is performing properly. It will probably be necessary to fool the sensor that went into the cat even if there is an insert point in the downpipe replacing the cat. Thats my $ .02 [:I]
Alan
Old 18 Aug 2003, 01:22 pm
If I were to go outlaw, I would probably opt for a 3" high flow cat. The one currently used has to be a max of 2" inlet/outlet. Must have been another one of those cost saving measures. Outlaw shops will swap out to a big cat for about $200. Pretty cheap considering.
Old 18 Aug 2003, 01:28 pm
In America those wastegates are inherently illegal, and if visible from the street will net you a fine. Uncle Sam thinks that from the air inlet to the end of the cat is holy ground and may NOT be modified. the only legal wastegate in the U.S. is after Cat, and that may be subject to local interpretation for sound considerations.
It makes you wish for the good old big block days, but they are gone forever now!
Old 19 Aug 2003, 12:38 am
Really? Banned in the USA huh? Good thing I'm in Canada and the Queen mum approves .
On the street you'd be running a stock exhaust, no excessive noise. At the track, you could run it uncorked and still not hear it over the big block next to you.
Marc
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
"Stage Turbo Forums" Killed by Mopar hyracer Stage Turbo Kits 20 28 Apr 2005 04:26 pm
Tour de Lance STAGE 13 UPDATED PTRON Non-PT Discussions 1 18 Jul 2004 09:02 pm
Tour de Lance STAGE 7 PTRON Non-PT Discussions 0 10 Jul 2004 07:13 pm
Stage 2 info from SRT-4 site dtbrks Stage Turbo Kits 24 26 Nov 2003 05:24 pm
