Dyno sheets before and after
Old 18 Aug 2003, 10:31 pm
Default Dyno sheets before and after
Used the scanner at work quality's not that great.
before
after
Tell me what you think!
Old 18 Aug 2003, 10:38 pm
nice jump in power, what kind of tq are you putting down?
Old 18 Aug 2003, 10:46 pm
now that you mention it I don't have the #'s on torque, but I can tell you from butt dyno I can light up the tires from a 25mph rolling start. I couldn't do that stock.
R_K_GT
\'03 Electric Blue GT, silencers removed, K&N intake, Blanes Hood Struts, Emblems removed from rear hatch, Stage 1, Mopar BOV, Eibach springs, 18x8 Mille Miglia EV-R on 225/40/18 BFG g-Force T/A KDW 2, Eibach sway kit F&R, BTG Strut Bar, Chrome fuel door, custom 3\" cat-back exhaust with Magnaflow High-flow muffler, Blitz Dual Turbo Timer, Autometer Triple gauge pod, Autometer Ultra-lite with boost/vac, oil press and water temp gauges, Turbochargers.com wastegate, turboxs DSBC, Adams UCP, Dynoworks motor mounts with more to come.....
Old 19 Aug 2003, 07:39 am
That's a huge differance for spending less than $400. I'm very happy with my Stage 1 results also.
My question is did you do anything between dyno runs as your peak HP varied by 10 HP on the different pulls?
Deen
Old 19 Aug 2003, 08:20 am
Great increase!!!
With the Average HP increase of 25 horses at the wheels, it proves that the K&N drop in, Silencers removed and the BOV in place proves that it made a little more than with the Stage one alone.
Rice Killing GT, do you have also a modded exhaust?
Ian
Old 19 Aug 2003, 12:06 pm
I still have the stock exhaust
R_K_GT
Old 19 Aug 2003, 02:50 pm
Wow! That is so cool. It was difinitely worth the install time just to see that dyno sheet. That is a huge increase when you think that you paid less than you would for many aftermarket exhaust systems.
Old 19 Aug 2003, 04:18 pm
Very nice numbers
2003 Inferno Red GT with a few chrome goodies.
Old 06 Jan 2004, 08:00 pm
Send a message via AIM to Rolo
Hey, rkGT, do you happen to have the tables (numbers) to these graphs?
before
after
Old 06 Jan 2004, 10:44 pm
Send a message via AIM to macster
Rolo
I just upsized Rk's images and stuck em into PwrPoint if you are interested. Sure would be nice to get RK's numbers to go with his charts. FYI, below are links to other dyno info found on this site.
http://www.ptcruiserlinks.com/forum/...archTerms=dyno
http://www.ptcruiserlinks.com/forum/...archTerms=dyno Good stuff here
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
