stage one burning my sensors ?
Old 06 Jan 2009, 02:16 pm
Default stage one burning my sensors ?
hi ever since i put my stage one in my sensors seem to be going, replaced 2 already and one more is on the way. another thing my engine light does not come on with my stage one. when my car starts running like crap i have to put in my old computer and the the engine light comes on and i can look up my error code wtf ????? help any comments appreciated. murray
Old 13 Jan 2009, 09:58 pm
Gold GT's Avatar
Default Re: stage one burning my sensors ?
Maybe a stupid question but firstly are you running premium? Second question which sensor's did you have to replace?
'04 Gold GT 5spd (there is no other way)
Mopar Stage 1 upgrade, Mopar BOV Conversion, AEM CAI, High Flow Haynes Plastic Intake Manifold, MSD High Voltage Ignition Coil Pack, MagnaCore Spark Plug Wires, AutoMeter Boost Gauge, Greddy Oil Catch Can, Hurst STS... Plus a much longer wish list
I DO ALL MY OWN WORK!!
Old 13 Jan 2009, 10:36 pm
yes i have always run premium gas. originally i had to replace 2 sensors not sure wich ones i would have to look it up on my mechanics bill. ok i went to replace my stage one with my stock pcm and i found what i think was power steering fluid all inside one of the plugs (the white one ) i cleaned it all out with wd40 and plugged my stage one back in. ran perfect. thank god. anyway i am still not sure how the power steering fluid got in must have a leak somewhere. this however does still not explain why the engine light will not come on with my stage one. is this normal i would think if somthing was wrong or missing or whatever i should still get error codes with my stage one but this is not the case ? i am sure this is not normal
Old 16 Jan 2009, 12:16 pm
What color was the fluid? Do you have an auto or manual? If the liquid is clear and you have a manual it is brake fluid from either the clutch or brake reservior probably. If it is red it is ATF and I am not sure how it got there. Either way I am not sure how the S1 would burn out sensors. Going over the various sensors in my head they pretty much just send a signal one way TO the PCM. The PCM then tells other components what to do based on that info and calculations. You have something else going on. It would help to identify the sensors replaced.
Old 19 Jan 2009, 12:59 am
ok i pretty sure the first 2 sensors were just worn out ...... when i got the fluid in my plug for my pcm it started running like crap like when the other sensors went. at any rate it was just the fluid disrupting the pcm. but i still the engine light should come on warning of missing or whatever, it never did when my first 2 sensors went or when the fluid mysteriously got on my pcm plug. i had to put my old pcm back in so the engine light would come on and i could look up the error codes ??? with my stage one the engine light never comes on even if it should. anyway its running good now and i am happy ....... although i am selling it now cause i bought a sport trac ......... i will miss it ......
Stage II for PT is here! skripo General Turbo Discussions 9 12 May 2008 09:11 pm
Are there any step by step instructions for mopar stage 2 wastegate and or dual stage dmkolb Turbo Performance 4 29 Nov 2007 03:52 am
Stage 1 and 2 modules on Ebay pdbrains Stage Turbo Kits 3 16 Aug 2007 12:06 pm
Tour de Lance STAGE 7 PTRON Non-PT Discussions 0 10 Jul 2004 07:13 pm
Stage 2 info from SRT-4 site dtbrks Stage Turbo Kits 24 26 Nov 2003 05:24 pm
  Wordpress Theme | WoW Gold | Manga | Debt Consolidation | Wordpress Themes
