Going to the dyno today
  #11 (permalink)
Old 21 Aug 2003, 11:45 am
Ian,
This is probably the perfect example why the Stage II kit will have a selectable boost control. I am seriously concerned about how 260 horsepower will stress the non limited slip drivetrain and relatively skinny tires on our PT.
  #12 (permalink)
Old 21 Aug 2003, 11:56 am
Ian -
So you removed the A'pexi Controller? What did you do with it? I was very interested in one of them after seeing your results.
\"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety.\"
Benjamin Franklin, Historical Review of Pennsylvania, 1759
www.cybermopar.com
TripleJack
  #13 (permalink)
Old 21 Aug 2003, 01:52 pm
I have made two errors in my PT.
1.Mod the engine with $600.00 electronics
2. Remove them and sell them for $300.00
I removed it because I wanted to see the difference with S-1, But a friend of mine found it and gave me $300.00 for the S-1 Fund.
Now it lives inside a Supra, I want another one to increase boost to a steady 16 PSI now that I have better fuel flow...
If you get your hands on one, don't let it go... It is so flexible and tuner friendly!!! It can even monitor you injectors dutty cycles!
The only drawback is the same as with S-2 like Kirby said. You had to jump from one setting to another to meet your driving needs.
I had it inside my glove compartment with my TT, S/W controller, GPS (Like I realy need it in an Island) and my G-Tech... My friends called me Vin Deesel because I was allways switching back and fourth the settings on the controller...
This is how it looked:
[IMG] http://www.imagestation.com/picture/...e/fc00e5cd.jpg [/IMG]
Ian
  #14 (permalink)
Old 21 Aug 2003, 08:19 pm
Wow! 280ish TQ figures really impress me! You know what they say..."Horspower sells cars, torque wins races!"
  #15 (permalink)
Old 22 Aug 2003, 08:01 am
Ian-PT-GT,
Thanks for setting me straight! I should be running almost identical times to what you've posted since I'm also running S1, BOV, and the single BTG exhaust. I've run a best of 14.64 (factory tires, no power-shifting)with a MBC but haven't been back to the strip since the S1 addition. I've heard the S1 takes unkindly to a MBC...has anyone tried running both with a 16-16.5 boost setting on the MBC?
I do like running the S1 so far as I also turned the boost down on the MBC when running on the street...having your boost set low when someone pulls along side and challenges you is NOT a good thing!!!
  #16 (permalink)
Old 22 Aug 2003, 10:44 am
Send a message via AIM to Steve03GT
Thank you, thank you, thank you, Cal; I'm feeling vindicated.
\'03 GT Cruiser,White w/ Auto Stick, MOPAR Stg. I, AirAid intake,Alpine XM radio w/ 4 MBQuartz, Autometer Lunar Boost and A/F Gauges
\'02 Corvette (510 RWHP/510 TQ)
Member of 11sec. club &
NRA Benefactor Member
Evolution Performance Dyno Day - Saturday, 10/1 Evolution Northeast PT Forum 0 27 Sep 2005 01:12 am
2004 GT 5-Speed Dyno (Close to Stock) PTGT_Boy Turbo Performance 22 16 Oct 2004 02:56 pm
Dyno Results for Hahn Turbo PT!! Ant Turbo Performance 7 09 Feb 2004 08:27 am
dyno danger 026TB4U General Turbo Discussions 0 11 Jan 2004 08:14 pm
dyno done a few questioons 026TB4U Turbo Performance 9 19 Dec 2003 09:12 pm
