PT Cruiser Forum Car Videos
Custom Wheels
I put the Stage 1 in today...
  #11 (permalink)
Old 14 Sep 2003, 10:17 am
macster macster is offline
Send a message via AIM to macster
PT
You might want to take a good look at the idler puller and pwrstring/A/C belt area. I would jack the car up pull the right inner W/Well sheild and bottom splash shields out. It should take you about 10 minutes, unless your car is lowered like mine, then it takes 12. Anyway, what this does is as follows, its provides much better viewing in/around those areas, plus you can really look if you have an inspection mirror and a MAG light. You really don't want anything like that floating around in that area.
FWIWM2C
macster
Don\'t help me
Help the bear
Patriot Blue PTGT, Stage1, K&N Typhoon, 2.5\" Cat back exhaust, Sun Hyperground, Sun HOT INZAMA Hyper Voltage system, Adams Uppipe
  #12 (permalink)
Old 14 Sep 2003, 10:48 am
PTGT Redman PTGT Redman is offline
thanks. it's up on rhinoramps now.
It makes me nervous esp on that side cause of all the belts.
Homepage:
  #13 (permalink)
Old 14 Sep 2003, 12:47 pm
k. found a high torque 6mmx 25mm bolt at home depot. Fits perfectly.
Took the shield off the lower belt assembly and found the lug nut sitting right against one of the belt pulleys. Lucky I got it, woulda been ugly if it got caught in the belt assembly.
Well, gonna fill it up. Hope it doesn't leak or explode.
Homepage:
  #14 (permalink)
Old 14 Sep 2003, 03:39 pm
Cal Cruzer Cal Cruzer is offline
Addressing the fuel pressure release, there is a schrader valve on the end of the fuel rail (like a bicycle tire inflation valve). Just wrap a rag around it and depress the center pin and it will relieve any pressure in the system.
  #15 (permalink)
Old 14 Sep 2003, 06:55 pm
SteelBlueGT SteelBlueGT is offline
Cal Cruzer, that seems easier than my method wich I got from the DC repair manual! Has it ever created error codes???
  #16 (permalink)
Old 15 Sep 2003, 03:19 pm
Kirby Kirby is offline
It cannot create an error because in the install, the battery is disconnected. The ammount of fuel is so small, much ado about nothing!
vB code is On
Got My Stage 1 Flashed Today LAF Stage Turbo Kits 16 17 Jul 2007 01:30 am
oredred stage 1 today deez92 Stage Turbo Kits 5 08 Dec 2004 11:51 pm
Kudos tthrift...Stage I arrived today! Adman Stage Turbo Kits 1 19 Sep 2003 07:38 pm
Stage 1 mailed Fri, got it today LAF Stage Turbo Kits 3 08 Sep 2003 11:04 pm
STAGE 1 SHIPPED TODAY !!! gsharrock Stage Turbo Kits 18 07 Aug 2003 07:22 am
  Debt Consolidation | Loans | Cheap Loan | Remortgages | Online Loans
